Question about Canon imageRUNNER C3220 Color Copier
Error code E000732-0001
Please someone help, I have a Canon C3220, keep geeting error code E000732-0001, what is this mean, how can i fix it.
Thanks to any one who could help.
  • arya_mega66
    arya_mega66 Feb 24, 2013
    how to cope with E000732-0001 IR 2870 sir please clear you know?
    Sniper:
  • 118 Answers
This error indicates that it cant detect the scanner unit of IRC3220
Check the cable that connect the machine and scanner unit .switch off the machine disconnect the cable and reconnect it and switch on the machine again hope this will help
Posted on Jul 01, 2009
  • arya_mega66
    Like where do you overcome E0007320001 the IR2870, sometimes he would not, and he sometimes displays an error E000732-0001 and in order in turn, like a mama to fix, please give to know how?
    New Friend:
Please how ca you cope with error code e 0007320-0001
Posted on Oct 04, 2013
    New Friend:
  • 8 Answers
Posted on Jan 20, 2013
How to repair canon ir C3220 Error Code E602-0003
This is just a shot in the dark, but if there is no "reset" button, you might try unplugging it for a couple of minutes and it should reset itself to factory default settings. Just a guess. If you have an owners manual, I would check there to find how to solve the problem. You might want to enter the "menu" if there is one, and discover whether you can solve the problem there. If you don't have an owner's manual, you might be able to find one at the printer manufacturer's website in the support section.
Nov 11, 2013 | Canon Color C3220 Copier - Color...
Cannon c3220 error code E000355-0001
I have Canon C3220 and it is displaying e000355-0001 anytime i switch it on. pls help me solve this problem. Thanks.
Aug 22, 2012 | Office Equipment & Supplies
Canon ir c3220 color copier error E000020-01b0. What means? How solve that error?
Canon Error Code E000020 01b0
Although the yellow drum is indicated, in the link above, please note it may not be the yellow drum if instead it is the:"laser shutter or the plastic actuator on the right side of the front door."
Jan 24, 2018 | Office Equipment & Supplies
Error code E000003-0001on Canon ir C3220
this is problem with the thermistor .
because the fixing temperature doesn't rise. maximum rise up to 70 degrees C.
solution is change the thermistor with a new.
Jul 21, 2011 | Canon imageRUNNER C3220 Color Copier
Error Code E00110-0110 "Canon C3220"
The only way for you to resolve this problem is to access the yellow laser motor. Unfortunately, you need to remove the laser and check for rotational operation and replace if necesary. That's it - no one can do that for you but you.
Sep 23, 2009 | Canon imageRUNNER C3220 Color Copier
Canon Imagerunner 2200 with error code e000000-0000
Try to enter service mode, and from function clear the error.
Switch off and on. If the problem persists you have a problem with your fixing unit...
Sep 02, 2009 | Canon imageRUNNER C3220 Color Copier
Canon Imagerunner 2220i Error Code E000000-0000
canon printer ir 2200 error E000000-0000 my help
Feb 05, 2009 | Canon imageRUNNER C3220 Color Copier
Canon imagerunner c3220
Were the heaters at fault. It is more like a thermister problem. Replace the thermisters, both. And I would also change the thermostat as well. When you are sure thatyou have removed the faulty unit reset by doing the following.. service mode/copier/function/clear/error followed byswitching the machine off and turn on again.
Oct 31, 2008 | Canon imageRUNNER C3220 Color Copier
Error Code E000-FF13
E000 error in a Canon is a problem w/the fuser (exit where it gets hot)\
Check thermistor, thermofuse or lamp
Oct 13, 2008 | Canon imageRUNNER C3220 Color Copier
Canon imageRUNNER C3220 Color Copier Logo
2,031 people viewed this question
old marine
old marine
