Question about Iomega 1TB Desktop USB 2.0 Hard Drive
My computer does not read iomega hard drive - Iomega 1TB Desktop USB 2.0 Hard Drive
  • 158 Answers
Make sure that your computer has usb2 ports. Older computer have usb1 ports. A 1 tb hard drive may require the newer faster usb2 port. If it is a desktop computer you can get usb2 cards or if it is a laptop you can get a usb2 converter. You may just have a driver issue. try the cd that came with the hard drive. Make sure your system is compatible.
Posted on Jul 01, 2009
SOURCE: IOMEGA eGo portable hard drive won't copy files from mac
Format your hardrive for Mac OS:
Go to Disk Utilities under the go menu in your finder. Select the external drive and click on the erase tab. Clikc erase again and it formats the drive. You can now copy files onto the drive.
Posted on Feb 08, 2009
Crankstart
  • 696 Answers
SOURCE: What does it mean when my 1TB Iomega external
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist. In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Posted on Jul 08, 2009
  • 164 Answers
SOURCE: computer doesn' t recognize iomega eGo portable
a windows update may have run and killed the drivers...try rolling the system back to before the problem started, then if updates run again..and set them to download but dont install..install them yourself..run updates and see if the problem re-appears.
Posted on Jul 24, 2009
  • 739 Answers
SOURCE: cannot copy files to Iomega 500 GB external hard drive.
It depends on how you formatted the the drive.
If it was formatted FAT it will work on both Mac and PC.
If you formatted to HFS+ (the native mac format) then it will only work on a mac.
Posted on Sep 17, 2009
  • 60 Answers
SOURCE: my playstation 3 wont read my iomega external hard
Format to fat32.
Posted on Nov 29, 2009
Iomega LDHD-UP hard drive containing dj music and will not read device on any computer to retrieve music
Sounds like the drive might have died. Only way to tell is to install a program like "Hard Disk Sentinel" to check it, It displays a lot of information that may not be of use, but it does tell you the health status of the drive at the top of the program.
Jan 15, 2015 | Iomega Computers & Internet
My iomega hard drive doesnt appear under my computer, it appears in dev. mgr but cannot assign a letter. Windows makes a sound to recognise its there, its says usb recognised and ready to go. just cant...
Iomega portable hard drives connect to your computer through a USB port. When you connect the Iomega hard drive to your computer, it should pop up as an icon in your My Computer folder. If you can't find the icon in your My Computer folder then you probably need to update the driver for the device. Updating this driver is not very hard and can be done automatically from the Windows Device Manager.
Plug your Iomega hard drive into one of your computer's USB port. Click the "Start" button and go to the "Run" field. Type "Devmgmt.msc" into the Run box and press the "Enter" key. Go down to the bottom of the device manager to the "Universal Serial Bus Controller." Click on the little + (plus) sign to expand it. Look for an entry with a yellow exclamation point and click on it. Click the "Install the software automatically (Recommended)" button and then click the "Next" button. Click the "Finish" button when the installation has finished. Go to the "My Computer" folder from your "Start" menu and locate the Iomega hard drive icon. Double click the icon to gain access to the external hard drive. Hope it helps.
Jan 22, 2013 | Computers & Internet
My Iomega hard drive isn't working whenever I plug it in to my computer I hear a clicking noise but no response, meaning my computer or others are not reading it.
noise coming from a hard means that the hard drive is already have a problem and if it is not read by the computer it is already broken you must replace it.
Aug 01, 2011 | Iomega Computers & Internet
How do I get a users manual to learn how to fully operate my new iomega desktop hard drive
According the the website, the manual is on the drive. To get to it all you need to do is first plug power into the hard drive. Then plug the USB cable from the hard drive into the computer you are using. Then go into My Computer and select the drive. You should see the manual there. If you cannot read the file download this and install this: http://get.adobe.com/reader/. It is a pdf reader which is what the manual file is going to be.
May 12, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
I have a DVD player with a USB port. When I connected the iomega drive , the dvd player can not read the hard drive. However if an USB 4GB onnects to the player , It will read?
The most likely cause is the 1Tb hdd has an NTFSfile system and the 4gb usb is a FAT32. To check, right-click on the drive in "My Computer" and look for "File System". it's right above the storage information.
Mar 22, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
My mini max 500gb has just stopped working. i cannot hear the fan at all and all my other daisy chained mini max hard drives still work and register on my desktop
Your Imega external enclosure has malfunctioned. If you can, you need to take the enclosure apart and take the harddrive out and test it with a computer desktop that has sata connectable, if your computer is able to read, then your iomega harddrive enclose suffer malfuction, if the computer isn't able to read the harddrive through the sata connection, then your harddrive is bad.
Jan 30, 2011 | Iomega MiniMax (33464) 250 GB Hard Drive
My iomega 1tb is "read
Any Hard drives before getting to used with MAC OsX has to be formatted according to the MAC file system...
I think that is the problem you are facing...
Make sure your hard disk is not formatted for any windows OS and try to reformat for MAC OsX...
It should work...
Dec 09, 2010 | Iomega 33089 250 GB Hard Drive
Could not find pretige iomega icon on my computer
format the harddrive as MS-Dos to be able to use it on Mac and PC.
Apr 17, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
Problem with Iomega Portable Hard Drive
Sounds like the drive is dead, even though it powers up the disk might not be spinning or the read heads could be stuck. Depending on the data you have on it and if you have it backed up or not, you could send it out for to have the data pulled off it but I warn you it is not cheap.
Dec 31, 2009 | Iomega Computers & Internet
Iomega 1TB Desktop USB 2.0 Hard Drive Logo
533 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
