Panasonic VIERA TC-P60GT50 60-Inch 1080p Full HD 3D Plasma TV Logo
A
Anonymous Posted on Aug 16, 2014
What is causing the black screen and 3 blink light?
3 blink power light. Black screen. Power switch does nothing. Unplugged power and HMDI cables. Re-Pugged in power. Same 3 blinks.
Level 3:
Top Expert:
  • Panasonic Master 76,851 Answers
  • Posted on Aug 17, 2014
Panasonic Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14995683
Points
237762
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
5 Related Answers
Anonymous
  • 934 Answers
  • Posted on Jun 04, 2007
SOURCE: Blinking Power Light
With just those set of symptoms - and nothing more - my first guess is that the power supply (PS) board has a problem. It is possible to replace the entire board, but it is also possible that the board could be repaired. The PS is not an inexpensive item so my best advice would be to have a professional look at it and estimate the problem. Then discuss the options repair/replace... Bill
Anonymous
  • 790 Answers
  • Posted on Oct 02, 2007
SOURCE: Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
djchillsnyc
charlie rodriguez
  • 152 Answers
  • Posted on Oct 31, 2008
SOURCE: PANASONIC TH-42PZ700U - WILL NOT POWER UP
THIS SYMTOM MEANS THERES A POWER PROBLEM DEPENDING ON HOW MANY BLINKS WILL TELL YOU WHAT BOARD OR PANEL IS BAD OR NEEDS TO BE CHECKED IT MAY BE A BLOWN FUSE
COUNT THE TIMES IT BLINKs and i can tell you what internal circut board is bad..
Anonymous
  • Posted on Jun 25, 2009
SOURCE: Panasonic Projection HDTV Made 9/2003
my problem is that when i turn on my t.v there is the sound that the t.v turns on but there is no picture on the sceen and everything is fully black....
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Apr 17, 2010
SOURCE: My panasonic 42" plasma wont turn on, but the power light blinks
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of anly a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
Toshiba regza tv went black while watching cable tv. Unable to view via antenna or fire tv. Power light blinks three times and then nothing for a few seconds Unplugged power strip for no results.
The LED on the left blinking green 3 times is power-up, the LED on the right blinking green 3 times is what Toshiba calls a "BUS Error" which basically means a hardware fault.
Credit...
10/08/2015 by Bill Wessendarp
I have a Plasma TV with black screen and 6 red light flashes.
Mitsubishi wd-60737 HDMI port 1 connected to cablebox. Screen is black and no sound. Cablebox is on, all cables connnected correctly and was previously working. Nothing new was done.
have you tried resetting your cable box? you can do this usually by either holding its power button in until all 3 lights light up, or by unplugging it from power , wait @ 30 seconds & plug back in .
My TV's red light won't stop blinking?
check your power supply to see if there are bad caps on the power supply
Sony KDL-40Z4100 standby light solid red, orange blinks every 4 sec, What part may have gone bad?
The red stand by indicates the set is in PC stand by the blinking orange timer is indicating the timer has been set or has an issue
MY COMPAQ CQ56-129NR when turn on the power light comes on then cap light blinks but no start up screen. Screen stays black what can i do if anything?
This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
2helpful
My ps3 screen went black nothing on screen tried new scart plus hmdi cable keeps saying unsurported
Hi, you may try to reset your video settings. It's pretty simple: switch on your console, hold on the switch until you hear 2 beeps. Now video settings are reset. Hope you get rid of this issue. Regards, Peter
Black screen
how can u fix this black screen? the green power light is on, shows vista for a bit then turns black and stays black. any solutions or do i have to send it back?
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
