Beko washing machine wont drain or spin water stays in drum
Can put machine on fine does go through a normal wash till it goes on the spin .machine wll not spin or drain water .ive emptyed the machine for now .the gray pipe at backs not blocked or the part at the front bottom were i emptyed the water from is fine .what else could be wronge
  • Anonymous Mar 27, 2014
    hello can somebody help me! i have a hotpoint aquarious washing machine and the water is draining but wont an anybody please help thanks spin!! ive cleaned filters pump and blown though pipes c
  • 25 Answers
The pump itself could be blocked or broken check inside pump first for any obstructions
Posted on Jul 16, 2009
  • Washing Mach... Master
  • 744 Answers
Hi Josephine if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Posted on Feb 14, 2015
Beko WMI71641 won't agitate or spin - drum doesn't move!
your pump is blocked,at bottom of machine there should be a flap with a round plug in middle .unscrew,it will have water come out so use a bowl or big towel.the impeller should turn freely,once plug is unscrewed at front put washer into a drain program see if the pump turns.if this is free youll need to get the pump off(unplug machine first)and then feel inside the big pipe from the drum to pump.it may have a sock or something like inside.this means it will work but wont get out all the water.also note when trying to spin a pillow,or big towel the load will be uneven so it will reduce its spin speed so it doesnt destroy its self
Apr 16, 2014 | Beko WMI71641 Built in washing machin
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Jan 28, 2014 | Beko Washing Machines
My washing machine fills up but the drum is not spinning
Hi calex if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Jan 18, 2013 | Beko Washing Machines
Beko washing machine not draining
If the drain hose is stretched too much to reach the standpipe, the hose can pitch.
May 21, 2012 | Beko WM5140W
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
Washing machine wont spin (beko 1512 s)
Hi if your beko 1512 s washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Mar 19, 2009 | Washing Machines
Beko w765s front loader wont spin
Hi if your beko w765s washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Aug 20, 2008 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
1,759 people viewed this question
Top Washing Machines Experts
