Question about Navman Tracker 5500i GPS Receiver
I want to download all my waypoints from my Navman Tracker 5100, and either use them in my stand alone Cmaps, or print them out
5 Suggested Answers
SOURCE: Navman 5500 tracker
Navman 5500 does not support C-MAP MAX maps.. only C-MAP NT+ maps.
Posted on May 02, 2008
SOURCE: navman gps tracker 5110i . lost the operation manual
Look Here....
http://www.navmanmarine.net/upload/Marine/Internet_Manuals/5500_5100/5500_5100_eng_web.pdf
Mark
Posted on Dec 17, 2008
  • 119 Answers
SOURCE: Instruction manual for NAVMAN Tracker 5430i
You can find the manual here:
http://www.navmanmarine.net/upload/Marine/Internet_Manuals/5430/MN000439A_T5430_EngManual.pdf
don't forget to rate, thks
Posted on Jan 08, 2009
  • 4090 Answers
SOURCE: slow at finding satelites
Most common reasons for this is that your battery level is low. Make sure it is fully charged before use.
Please rate my help++++Thanks for using FIXYA
Posted on Jan 12, 2010
Dear Sir.I would like to know that the availability of navman tracker 5505,5605 or 5507. I am ver interested to place an online order for the Tracker 5505.thank you. Ahmed Rasheed.Maldives, e mail. ah
The NAVMAN trackers are no longer available as the company stopped making marine products. You can however find current products at www.lowrance.com.
The closest you can find is a Lowrance Elite 5mHD
http://www.chsmith.com.au/Products/Lowrance-Elite-5m-HD-Chartplotter.html
In case you want to refer to a manual for 5505/06 refer this site.
http://www.navmanmarine.net/upload/Marine/Internet_Manuals/Tracker5505_5605/English_T5505_5605_manual.pdf
You can still find some old 5505 units at speciality marine online stores. Give this a try.
Northstar Navman TRACKER 5505
Aug 04, 2014 | Navman GPS
Slow at finding satelites
Jan 12, 2010 | Navman Tracker 5500i GPS Receiver
We keep loosing contact to the sattelites. Is there a way to reset it, so we get a constant signal?
Mine did the same, and said no gps no fix. I called the factory, now called Northstar, tech said to reset unit, and it worked. Great signal strength. Turn unit on and access menu, access factory settings,hit factory reset. However you will lose all your waypoints.
Jul 04, 2009 | Navman Tracker 5500i GPS Receiver
I have a navman 5500,I can hardly see the screen on a sunny day
the problem is that the controlling diode that checks LUX value is damaged (small clear window of minute proportion that adjusts screen brightness)
Jun 29, 2009 | Navman Tracker 5500i GPS Receiver
Navman 5500 gps backlight dim but set to max
Its water ingress causing a short in the high voltage wiring PCB.
Open the unit with a 1.5mm allen key, unscrew the power/data cable sockets with a spanner and GPS antenna inlet with an 8mm socket (NA to i models) .
Where water has arced there will be burning black on the green PCB evident, cut the PCB wire and remove the section around the burn.
solder a new wire to bypass the short.
Dry the unit and seal with silicone to prevent re occurrence.
Its a 2 hour repair requiring a high DIY soldering standard but off set it against the time it will take to reload you waypoints in a new plotter , its well worth the trouble.
DAKA
May 27, 2009 | Navman Tracker 5500i GPS Receiver
Navman 5500 tracker
Apr 24, 2008 | Navman Tracker 5500i GPS Receiver
Navman Tracker 5500 turns on but locks itself in the entry page
Have the same problem??
Used to take less than a minute to acquire satellites now takes 10-20minutes.
Nov 08, 2007 | Navman Tracker 5500i GPS Receiver
Navman Tracker 5500i GPS Receiver Logo
67 people viewed this question
Top Navman GPS Experts
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Navman GPS Expert? Answer questions, earn points and help others
