Question about Nokia 3110 Cellular Phone
Nokia 3110 won't save changes to contacts
My Mom's Nokia 3110 which was purchased just two days ago won't accept edited changes in Contact Details. Contacts were transferred via SIM card from Nokia 8210. There is no problem when entering a new contact but the message "operation failed" would appear whenever I try to edit the existing numbers which I transferred via SIM.
Hope you can help, Thanks!
  • Nokia Master
  • 1,800 Answers
Well the Internal Phone memory is full in most cases!
Posted on Jul 01, 2009
I forget my nokia5253 code plz what can i do unlock code
HI PZL TRY THE FOLLOWING THERE ARE THE LIST OF NOKIA
SECRET CODES .. >>
*#7780# Restores Factory
Settings (Memory, language,
counters are not included)
Nokia 3110 Secret Codes
*#746025625# [*#sim0clock#] : Checks if the
SIM clock can be stopped. SIM
clock stop is a kind of stand-by
mode which will save battery
time. This code doesn't work
with software version 4.59. Nokia 3110 Secret Codes
*#3110# : Checking the
phone's software (SW) - Also
called "Firmware Revision
Information".
Nokia 3110 Secret Codes *#92702689# [*#war0anty#]
Press the following warranty
code
7332 (OK) : Displays the date
of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial
Number
7832 (OK) : Displays (if found)
the date where the phone was
purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the
Purchasing Date MMYY
(Warning : You can only set
this once.)
Nokia 3110 Secret Codes 87267 (OK) : Transfers ALL
phone numbers, pictures,
sounds from one phone to
another
6232 (OK) : Displays the Month and Year of Manufacture
(0997)
This code is able to check,
activate or remove SIM card
restriction (SP-lock)
Use the * key to get the p, + and w chars
'Y' has to be 1,2,3 or 4 -
depending of what lock you
what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+3# for
Country-Lock status
#pw+1234567890+2# for
Network-Lock status
#pw+1234567890+4# for SimCard-Lock status # = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4 [Master Code] is a 10 digit
code, based on the phones
IMEI number.
[ No requests for the "Master
Code" will be entertained. ]
Nokia 3110 Secret Codes Eg. To remove restriction on
Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your
phone use 10 random
numbers Eg. 1234567890 as the (master code)
eg. To check if phone if
restricted on lock 1 type the
following code:
#pw+1234567890+1# 1: Insert sim card of different
provider.
2: Turn on the phone and press
the UP VOLUME key for 3 sec.
then release it and the phone
says PIN CODE? 3: Press the "C" key
4: Then Press * and wait until
it disappears and appears
again, then press * one more
time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or
ACCEPTED) and the SIM card is
accepted until you restart the
phone again. NOTE: On version
5.04 Nokia has removed this
option. Fast silent mode
*#06# : Checking the IMEI
(International Mobile
Equipment Identity)
Sep 09, 2016 | Cell Phones
Cannot edit contact information on my nokia c3
You have to copy all your sim contacts on your phone memory. Then you will gain access to other features like( adding another number,email,picture,ringtone,notes,etc. And you have to check from phone setting which memory phone will use to create the newer contacts, you can let it ask you every time you create a new contact where to save,on phone memory or sim card. Good luck
May 16, 2012 | Nokia C3 Cell Phone
My imei no. is 354862026555404 i forget my security code plz plz plz give me a solution 2 unlock it....
HI
THERE ARE THE LIST OF NOKIA SECRET CODES ..
*#7780# Restores Factory Settings (Memory, language, counters are not included)
*#746025625# [*#sim0clock#] : Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
Press the following warranty code
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
6232 (OK) : Displays the Month and Year of Manufacture (0997)
This code is able to check, activate or remove SIM card restriction (SP-lock)
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+2# for Network-Lock status
# = DOUBLE-CROSS
Y = NUMBER 1 TO 4
[Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again. NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
*#06# : Checking the IMEI (International Mobile Equipment Identity)
REGARDS
ANIRUDDHA
Sep 21, 2011 | Nokia 3110 Cellular Phone
Mic is not working after change also
Hi, i have a lot of problems of my NOKIA 3110c previously i.e., from purchasing date to now, so many problem i face it, like ear phones not working, software problem, restarting every time, memory card failure, improperly working music player,...etc. NOW GPRS SETTING IS NOT ACCEPTING FROM ANY NETWORK, I STILL RESTORING THE SETTINGS AND CLEARING THE MEMORY, WHEN ANY SETTINGS IS RECIEVED BY AN SMS, ITS NOT ACCEPTING "ONLY 70 SETS ARE ACCEPTING, MEMORY FULL" THIS ERROR MESSAGE IS SHOWING.. PLEASE GIVE ME A SOLUTION TO MY PHONE MODEL... (srknth70@gmail.com) IS IT TRUE NOKIA 3110c PANEL COSTS Rs. 1700/- TOLD BY NOKIA CARE TILAK ROAD, TIRUPATI, ANDHRA PRADESH, INDIA
Feb 07, 2011 | Nokia 3110 Cellular Phone
How can reparing contact service problrm nokia 3110
Hi for this you have to contact nokia service center they will help you in this
May 14, 2010 | Nokia 3110 Cellular Phone
Can I assign specific ringtones to certain contacts in address book with this phone?
-Go to Menu
-Go to Contacts
-Select the particular Contact (ex: Mom)
-On the right of the screen there should be Option, select this
-Select Edit Contact
-Scroll down through the selections and it should say Ringer, choose this, make changes, save.
Nov 17, 2009 | LG Shine CU720 Cellular Phone
I am anable to on internet service of my nokia 3110. Please help me.
Please contact your network operator to activate your GPRS connection. Once you get it , just save the settings.
Apr 17, 2009 | Nokia 3110 Cellular Phone
Nokia E71 - Saving new contact
check your phone memory limit may be it is full.
if it is still empty u need to reset all settingms of your cell phone to factory defaults.
Go to setttings then reset your celll phone.
but i think your cellular limit is over for save new contact check it .
Apr 05, 2009 | Nokia Cell Phones
Nokia n85 email addresses
go to contacts there save the number of the person then go for edit contact ther press left button then ther u vil get id fill the id ans save the contact it vil be saved
Jan 20, 2009 | HTC Touch HD Smartphone
Nokia 3110 Cellular Phone Logo
105 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
