Question about Apple iPod MA446LL/A MP3 Player
Charging ipod my 30G photo i pod will not charge from my pc or mains, i have replaced the battery it worked for aprox 1 hour but still will not charge
  • Anonymous Nov 27, 2007
    i`m very disapointed of my ipod 30g latest gen.the only way i`ve been able to charge it so far is on a docking station,it does`t charge at all on the power supply.is it my power supply(griffin 5 volt) i`m just about to give up and trash the.....
  • 35 Answers
Have you tried connecting your ipod with a different cord? Or maybe a different charger? Also, try to plug it directly into the socket--not a power strip or something like that.
This is an interesting problem.
Posted on Nov 08, 2007
My I pod stopped working
How old is the battery ipod batteries can only be recharged a certain ammount of times before they need replacing
If an iPod appears not to turn on, check the hold switch on the device.
If this switch is activated while the device is off, it will not power on again until the hold switch is turned off.
If that is determined not to be the problem, the battery's charge should be checked. When the battery is no longer holding a charge, the device will not power on, but will show a battery icon on the screen for a few seconds.
If you see this icon while trying to boot up the iPod, just connect it to the USB cable and allow the battery to charge, which can sometimes take up to 30 minutes before the iPod becomes operable again.
If no battery icon appears when trying to turn on the device, try resetting the iPod.
Once reset, the device should turn on, but if it does not, the battery may need to be drained first (by leaving the iPod disconnected from power for up to 24 hours), and the reset procedure tried again.
hope this helps
Aug 19, 2012 | Apple MA146LL/A 5th Gen Video iPod 30GB -...
I pod displays "connect to power" then shows
It sounds like your battery is bad. They can be replaced readily easily. Batteries an be found on eBay for as little as $5 and directions to replace it can be found here:
http://www.ifixit.com/Browse/iPod
Jul 26, 2011 | Apple iPod MA446LL/A MP3 Player
How long to charge the ipod to your computer?
Fully charging the battery takes about 4 hours. You can also fast-charge the battery to 80 percent capacity in 1 hour (2 hours for iPod (Click Wheel)). Charging the battery may take longer if you're using iPod as it charges.
Mar 09, 2011 | Audio Players & Recorders
Bought ipod (white) 1 gig, from ebay .. will not play, will not start, just blinking lights. held play for 3 sec to get green light, still nothing, all controls only render orange and green blinking ......
Hi, problem can be solved. You need t look out for two things:
1. the battery of the i pod,
2. the memory of the i pod.
Checking the battery, the battery cell of the i pod might be too weak to power up the i pod, so you need to test with another battery before purchasing a new one. It may also need to be charged properly for longer hours before it can be able to power up the i pod.You can also check that out.
Checking the memory of the i pod. The memory of the i pod can also be the cause. Virus or corrupted applications can cause to malfunction.
After checking battery, if it does not work that means you will need to flash the i pod for the memory to be restore back to normal again.
Take care.
Apr 14, 2010 | Apple iPod nano
Will not charge, Ipod nano says that this accessory is not supported and shows that it wont charge the battery. also the Teac will not turn off the Ipod or turn it on or it just keeps running . Use to work...
Apple does this so that only Certified accessories have to software to make the hardware circuits charge an i pod, thats especially a problem with some sound docks, my i pod 2 gen works with only 1 of the 3 sound docks that i have tried, but i have a bluetooth i home so i play my music wirelessly
Oct 18, 2009 | Computers & Internet
Apple 20gb Ipod Mp3 Player
your battery has come to its end of shelf life.
buy new battery on e-bay...open i-pod insert...
charge for 3 hours...problem solved!!
battery will cost £6 on ebay uk
May 20, 2008 | Apple 20gb Ipod Mp3 Player With Click...
I Pod 4 Gb
Just charge the battery until the indicator says the battery is full.
well since its been connected for more than enought, disconnect it, you can also try reseting the ipod incase it has frozen
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
  • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
  • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
May 18, 2008 | Apple iPod nano
Creative not charging
there seems to be a problem with the batteries for the Zen. I have just sent mine in for warranty work as it will work if you have it plugged into an AC adapter but it won't work as soon as it's unplugged even after charging all night. The USB will not charge it either. Creative has sent a replacement unit, but there is a serious problem with the battery.
Dec 24, 2007 | Creative Labs ZEN Vision:M Digital Media...
My 30G 5th Generation pod is totally dead and will not charge even with a new battery
  1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer is not set to sleep, standby, or hibernate.
  4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    If the Apple logo does not appear or the iPod is not seen in iTunes, the iPod should be serviced.
Nov 22, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
55 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
