Question about Denon DVM-1815 Multi-disc DVD Player
Denon DVM-1815 want to read region 2 DVDs on a Region 1 coded
  • f_merenda Jul 01, 2009
    What do you mean for "mod disc"?
  • 10,515 Answers
If you want to play region 2 DVDs on a Region 1 coded, you need to have a regional code. You need to have a code in order to unlock the DVD player's. This is a technique used by most of the major companies to generate more revenue. If you fall under region 1 , unless and until you have the unlock code, you cannot use it outside your region.
To be honest with you, you will not find these codes online on an forum or troubleshooting site.There are certain sites who offer unlock code.
One of them would be :-
http://www.dvdunlocks4u.co.uk/
Hope i helped you.
DO RATE THE SOLUTION.
Thanks for using 'Fixya'.
Posted on Jul 01, 2009
  • 854 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
  1. Connect the DVD player to a display device
  1. Power up the DVD player
  1. Using the remote control type in 9876 then press search mode button on the remote control.
  1. When the tray opens insert mod disc and close tray.
  1. Please wait for the reading, erasing and programming process to complete (approximate waiting time 5 minutes)
  1. Tray opens remove disc (DO NOT CLOSE TRAY)
  1. Unplug from the mains (DO NOT CLOSE TRAY)
  1. Plug the machine back in to the power socket
  1. Power up the DVD player and enjoy your DVDs from different regions
Changing dvd region codes
You can't change the DVD coding. That part is how the DVD is recorded. However, your Mac will play DVDs from another region. It just typically defaults to one region. I have deleted the DVD player software (and preferences files) before and reloaded it to play DVDs from another region. If you plan to regularly play DVDs from multiple regions, you might want to look for special DVD software that will read DVDs from multiple regions.
Jun 30, 2014 | Computers & Internet
1815 denon won't load dvds but will load cds
Hi...
Buy a DVD cleaner disk ( radio shack or walmart or best buy)
Run it a couple times
Aug 26, 2010 | Denon DVM-1815 Multi-disc DVD Player
Cant play dvd baught in england. player baught in the usa
There are different region codes for dvds and the player may only be able to play dvds with a north american region code.
Sep 08, 2009 | Radio Shack Accurian LMD-5108A Portable...
Change Region Codes to read all DVD's
Go into the menu, select the lock icon and press '0' on the remote 7 times, then enter the region you want ie, press 1 for region 1, 2 for region 2 etc... You can press '0'
Apr 24, 2009 | Televison & Video
Region problem and disc not reading
For your region problem:
1. Be sure there is no any disc inside the device.
2. Power on your player
3. Press <Menu> on remote
4. Using your remote control enter the code below, note that you must know what Region your player is CURRENTLY set to in order to know which code is appropriate:
for Region 1 use 2, 9, 3, 3, 4
for Region 2 use 3, 8, 7, 6, 7
for Region 3 use 5, 6, 7, 3, 2
for Region 4 use 7, 6, 8, 8, 4
for Region 5 use 5, 3, 8, 1, 4
for Region 6 use 2, 4, 4, 6, 2
5. A code should be displayed on the screen indicating the current Region setting of your unit.
4. Press the 9 (or 0) button on your remote control for Region free, or 1 for Region 1, 2 for Region 2 and so on...
5. Double press the <Menu> button on your remote
6. Enjoy :)
For vcd problem...Make sure that the Cd is written in a format which is compatible with the format with your dvd player. If you have a dvd player that can play formats like, avi, wma, etc. check that your cd writer is set on high quality mode and that the writing speed isn't set too fast. hope i was able to help^^
Jan 03, 2009 | Samsung DVD-R135
Region setting on Acer Aspire 8920
Older DVD drives use RPC-1 firmware, which means the drive allows DVDs from any region to play. Newer drives use RPC-2 firmware, which enforces the DVD region coding at the hardware level. These drives can often be reflashed with hacked or Australia and New Zealand (hardware region coding prohibited by law in these countries) RPC-1 firmware, effectively making the drive region-free. However, this usually voids the warranty and can render the drive inoperable if something goes wrong... better contact your laptop manufacturer regarding this
Sep 26, 2008 | Acer Aspire 8920-6048 Notebook
Changing the region code
You can only change the region code a few times (usually 5), so I wouldn't do it. You should leave the current player at region 1, and buy and install another DVD player and set it to region 4, then you will have 1 for each region you want.
Aug 15, 2008 | Samsung DVD-R155
Philips 7" DVD portable player
The PET702 will be a region 5 machine, whereas the UK DVDs are region 2.
DVD players from a particular region are designed to play only DVDs from the same region, due to copyright and distribution rights in each country or region.
However the PET702 can have the region protection removed by making it multi-region:
Switch on the PET702 and Open the tray.
Press SETUP button on the remote control, which will bring up the menu.
Highlight "PREFERENCES" and press OK.
Press [2], [5], [2], [3], [1], [5], [LEFT], [DOWN]
The screen will show: "Region Code: 2"
Press [1-6] to manually set the region OR [0] for multi-region.
You will now be able to play DVDs from anywhere in the world.
This is particularly useful, because region 1 DVDs from the US often come out when the movies are still in the cinemas over here. Region 1 DVDs can be bought perfectly legally by mail order or from the internet.
May 07, 2008 | Televison & Video
Programmed for region 2....Need to change to 1
Q: What is Regional Coding enhancement(RCE)?
A: It's a digital enhancement added to some Warner Bros and Columbia DVDs to stop region 1 (R1) DVDs from playing on Region-free DVD players.
Q: What's the difference between Region Coding and RCE?
A: Regional Coding enhancement(RCE) is an additional layer of protection which some studios have placed on select REGION 1 DVDs to prevent them from playing on region-free or multi-region players. Region Coding is a part of the DVD spec which divides the world into 8 regions:
Region 1: U.S., Canada, U.S. Territories
Region 2: Japan, Europe, South Africa, and Middle East (including Egypt)
Region 3: Southeast Asia and East Asia (including Hong Kong)
Region 4: Australia, New Zealand, Pacific Islands, Central America, Mexico, South America, and the Caribbean
Region 5: Eastern Europe (Former Soviet Union), Indian subcontinent, Africa, North Korea, and Mongolia
Region 6: China
Region 7: Reserved
Region 8: Special international venues (airplanes, cruise ships, etc.)
Basically, DVDs released in each region will typically only play on players sold in that region. IE a DVD released in the UK *Region 2* would not play on a player sold in the us *Region 1*. You can tell what Region a DVD is coded for by looking at the back of the box for a Globe with a number on it. The number correlates to the region list above. If a DVD is listed as 'Region 0' it means that it isn't coded for any region and should play on ALL regions players.
Dec 14, 2007 | Philips 30DV693R 30 in. TV/DVD Combo
Denon DVM-1815 Multi-disc DVD Player Logo
97 people viewed this question
Top Denon Televison & Video Experts
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
