"Perfect Focus" problem on Samsung HCN4727W
I had the usual Samsung convergence problems on a Samsung HCN4727W5S/XAA rear projection TV. The STKs and resistors were bad. I replaced the convergence board and the convergence issues were almost completely gone. The user accessible red and blue convergence and perfect focus all worked fine. The only problem was a very small 1/16” red convergence line on a small part of the user convergence screen.
I downloaded the service manual; then was able to enter the service menu and service convergence modes and adjust the convergence slightly to eliminate the slight red mis-convergence.
I do not have a screen jig, but used two pieces of string taped to the TV to mark both the edge sensors and the center of the screen. The convergence grid is square with no distortions and the center lines line up precisely with the sensors and screen center.
I was careful to save the RBG adjustments during the service menu convergence procedure and did the “Perfect Focus” from the service menu at the end of the convergence procedure.
The “Perfect Focus” within the service menu does not seem to finish and save the settings. It goes through 100% a few times, the RBG lines pass through the plane of the sensors, the numbers adjust, but the process ends with a white screen instead of reverting back to the convergence grid as the service manual seems to say it should. I exit the convergence procedure with the “s-mode” key as the service manual instructs.
When the TV is back on in the normal user mode, the picture looks good but the “Perfect Focus” function no longer works. I just get the “no sensor data” error message. I assume this is due to the “Perfect Focus” function in the service mode not finishing and saving the data.
The “Perfect Focus” did work after replacing the board before I started fine tuning the convergence in the service mode.
Any ideas is to what I am doing wrong?
Thanks
Michael
    President:
  • 3,130 Answers
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Posted on Nov 09, 2007
Samsung HCN5529W 55in Rear Projection can't Perfect Focus
hello What you have is a convergence problem. There is 2 modules inside your set that aligns the colors to have the same geometry and superposed . It is a common problem in rear projection tvs ,
You don`t have to worry about your blue tube , i`m sure it is perfectly fine, it just needs to be aligned through the convergence circuit.
Most often the problem is with those convergence modules that are faulty and need to be replaced.
Hope this will help good luck
Dec 07, 2009 | Samsung HCN5529W 55" Rear Projection...
Convergence
This is an indication that the STK is bad. The PC board should be marked to indicate which one if for the green.
Dan
Apr 13, 2009 | Samsung HCM422W 42" Rear Projection...
Red will not focus but blue will ...perfect focus stops in middle
REPLACE THE 2 CONVERGE I.C.'S. PLEASE LET ME KNOW IF FIXED. THANKS.
Mar 15, 2009 | Samsung HCN4727W 47" Rear Projection...
Perfect focus reads "no sensor data"
hope this helps check out this above links
please check out this links
for convergence board ics reparing it your self
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
and for convergence settings
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
thanks.
Oct 09, 2008 | Samsung HCM5525W 55" Rear Projection...
HCN4727W Convergence issue
Repalce STKs with 392-040 resistors should be 3.9 ohms,also you might want to join Repairworld it is for members who have TV shops over 7,000 different shops / lots of good techs there.They will not put up with anyone just looking to repair there own tv .Sorry unable to help with cz140,141.will do some checking you also can order whole convergence board.
Sep 08, 2008 | Samsung HCN4727W 47" Rear Projection...
Convergance
you need to have both convergence ics replaced STK392-040 (2).resistors 3.9 ohms they will be open.
Jul 27, 2008 | Samsung HCN4727W 47" Rear Projection...
Blowing Convergence Amp Boards
either the DCU Digital convergence Unit or the velocity board are most likely the fault.
Jul 10, 2008 | Samsung HCN4727W 47" Rear Projection...
Samsung HCN4226W blue color outlines
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
This convergence board works with the following Samsung television models: HCM4215W, HCN529WX, HCN559WX/XAA, PCN5425R, HCN4226WX, HCN529WX/XA
Mar 10, 2008 | Samsung HCN4226W 42" Rear Projection...
My samsung projection tv #pcl5415r don't want to perform perfect focus adjustments
perfect focus functions are based on service mode setup...or factory settings. if the alignment of these setting are loss then the unit wont perfect focus. does the unit have a complete loss of convergence. a complete loss of convergence indicate possible failure of convergence amps.
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
Samsung HCN4727W
Replace convergence amp IC's = tech skill required.
Then activate auto focus...............T.
Let me know if you want step-by-step help....................
Nov 18, 2007 | Samsung HCL4715W 47" Rear Projection...
Televison & Video Logo
400 people viewed this question
Top Televison & Video Experts
