Question about Verbatim STORE-N-GO (95312) 8 GB Hard Drive
Flash drive USB connector came loose
My flash drive's usb connector has come loose from the drive. I need to retain valuable information off the flash drive. Please advize?
  • 4 Answers
We do next-day data recovery for under $100. ($50 for students)
www.24hourdatarecovery.com
Posted on Jul 05, 2009
How do I Transfer photos from phone to flash drive
You'll need a physical USB OTG (On-the-Go) cable with a male micro USB connector-to-female full size USB port, or you need too have a flash drive with micro usb connector.
Jan 28, 2017 | Cell Phones
How to view contents from flash drive
There are external memory card readers, you can connect to any USB port of all modern computers. Perhaps even your flash drive has an USB connector, so you can put it in an USB slot from the computer.
If the flash five is a mini or micro SD card, you need an adopter from Mini (Micro) to SD ann that combination should be inserted in the external memory card reader.
Sep 26, 2014 | Electronics - Others
How to unlock partition on flash drive
USB flash drives are small, convenient storage drives. Place data such as pictures, photos and text on them quickly and efficiently and then carry it to another computer for copying to its hard drive.
A USB flash drive that has security enabled in it must be 'unlocked" before it can be used, which becomes difficult if the password has been lost. Because the security on the USB flash drive is rudimentary, a number of methods, from built-in software to optional programs, can remove the security so that the drive can be used.
Plug the USB connector of the USB flash drive into a USB port on the PC. Right-click on the icon of the USB flash drive when it appears on the desktop of a Windows-based computer. Select "Format" from the pop-up menu. Follow the command prompts in the window that appears to format the USB flash drive. Click "Done" in the confirmation window when it appears. The USB flash drive can now be used because the security has been removed from its storage space. Plug the USB connector of the USB flash drive into a USB port on the Mac. Double-click on the Mac's Disk Utility program, which comes free with the OS X operating system and is in the "Utilities" folder on the hard drive. Select the icon of the USB flash drive in the left column of the Disk Utility program's main screen. Select the "Erase" tab at the top of the Disk Utility program's main screen. Click on the "Format" check box on the right side of the Disk Utility program's main screen. Select "Fat (32)" from the drop down menu below the "Format" check box. Click "Format" at the bottom of the Disk Utility program's main screen. Click "Format", again, in the confirmation box that appears. Quit the Disk Utility program when the formatting is done. The USB flash drive can now be used because the security has been removed from its storage space. Download a password protection program to the computer's desktop; for example, the free TrueCrypt password protection program (see the link Below). http://www.truecrypt.org/downloads Double-click on the icon of the password protection program when it has fully downloaded. Follow the command prompts to install the program onto the computer's hard drive. Restart the PC after the installation has been completed. Double-click on the password protection program to launch it. Wait for the password protection program to recognize the USB flash drive and display disc letters for the drives attached to the computer in the left column of its main program screen. Plug the USB connector of the USB flash drive into a USB port on the computer. Wait for a letter to appear in the left column of the password protection program's main screen. Use the mouse to click once on this letter which represents the USB flash drive. Click on the "Volume" or "Volume Tools" button to open a new window. Click on the "Next" button in the new window. Erase the password in the "Password" column of the new window that appears. Erase the password in the "Confirm password" column. Click on the "Next" button to go to a new screen. Select "Traveler Disk Setup" from the drop down menu below "Tools" at the top of the password protection screen. Click on the "Open Explorer window for mounted volume" check box in the new window that appears. Click the "Create" button at the bottom of the window. Click the "OK" button on the confirmation window when it appears. Quit the password protection program. Drag the icon of the USB flash drive to the Trash or right-click on it and select "Eject" from the pop-up menu. Remove the USB flash drive from the computer's USB port. Plug the connector of the USB flash drive back into the computer's USB port. Double-click on the icon of the USB flash drive when it appears on the desktop to open its window now that the security password has been removed. Plug the USB connector of the USB flash drive into a USB port on the PC. Go to "Start" and select "Run" from the pop-up menu. Enter "regedit" into the text column that appears and press the "enter" key to run the registry editor. Press the "Browse" button on the registry editor's main screen and navigate to the following path on the computer's hard drive: "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies" Click "OK" to close the window. Double-click on the "WriteProtect" text that is in the right column of the registry editor's main screen. Enter "O" into the "Value Data box" in the window that appears. Click on the "OK" button to close the window. Quit the registry editor program. Restart the PC. Double-click on the icon of the USB flash drive that is on the desktop to open its window and access the files now that the security write protection has been removed.
Hope this helps.
Jan 17, 2013 | SanDisk Electronics - Others
I can't open because of the paSSWORD IN IT.
Hope this helps.
Jan 17, 2013 | SanDisk 2GB microSD Memory Card
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My 1gb flash disk tells me its write protected
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 19, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Strange files on usb drive
The only thing that can make that to your flash is a virus or physical damage to your flash of which i syuspect much of the former.
Do you update your antivirus before running these clean up checks.
If your information on the flash is backed up somewhere or is not that much valuable (which i doubt ) try reformating your harddrive.
If reformatting does not work then it means your flash was physically damaged.
Mar 25, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Flash disc ( stick ) will not work
Some flash drives have a case that is too fat to be fully inserted in usb connector of some PCs, I have has the same problem, try a short usb extension cable, worked for me.
Oct 21, 2007 | Lexar FireFly 2GB USB 2.0 JumpDrive
Computers & Internet Logo
825 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
