Indesit 1600 WIE167 washing machine
A wire from a bra has got inside the drum of my washing machine and is making a clicking noise when the machine is running. How do I get into the machine and retreive the wire?
  • 25 Answers
Locate element and remove you should then be able to remove bra wire they normally get caught around element
Posted on Jul 16, 2009
Clicking noise
More than likely a bra wire stuck,,,get a torch,stick ur head inside drum & have a look,,,pulled hundreds out over the years
Jun 16, 2013 | Maytag Washing Machines
Bra wire stuck in washing machine
You could try a very thin pair of twezers, or a very thin magnetic pick up tool,you might be luck.. if not the only other way is to remove the ruber door seal to get acces to the inside of the drum.
Dec 28, 2011 | Electrolux Refrigerators
My washer makes a click noise 2 times per rotation on the spin cycle. Even when empty, when i turn it the same noise happens.
typically a bra wire under the drum will cause this noise. a faulty motor will do it but with 10x more clicks . so look for rogue underwire.
Nov 09, 2010 | Washing Machines
Indesit WIE167 washing mashine
Remove the rear panel of the washer.
You will see the heater element at the rear of the drum,it has 2 wires going to it.
The thermistor as it is called is located at the end of the element,, unplug the connector on the thermistor. and pull the old one out, refit new thermistor, and connector.
Plz rate my solution.
Thanks.
Jan 06, 2009 | Indesit W 123 Front Load Washer
Fix my machine
Hi vickie234 Quite often the noise can be attributed to something getting between the inner & outer drums. If I had a dollar or pound for every under bra wire I have removed from washers I would be a rich man. Occasionally the clips that hold the element in place between the drums can also cause this same noise. Turn the drum slowly with your hand & see if you can hear the wire or clip. The only solution to this is to remove the wire. Not easy if you haven't done this before. Reagrds
Jul 22, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
353 people viewed this question
Top Washing Machines Experts
