Question about Nikon Coolpix 2100 Digital Camera
The lens will not close - Nikon Coolpix 2100 Digital Camera
  • 3 Answers
I've got this problem before. what i did, out of desperation, i slapped the camera 3 times. then switch on/off button, lo behold, the lense open & close like normal...
but do this at your own risk:
1. hold with right hand, camera with bottom side down.
2. open left hand palm.
3. smack left palm with camera bottom.. 3x...
let me know if that works..
Posted on Jul 23, 2009
Best settings for close up
That depends. A true macro lens allows you to get a 1:1 reproduction ratio; most manufacturers call a lens "macro" if it allows 1:4 or so. Some lenses work better for close work if you reverse them, using a reverse adaptor to put the nose of the lens onto the mount. Bellows and extension rings behind the lens will give you sharper results than close-up adaptors that screw onto the front of the lens.
The focal length will affect perspective; to get the same image size with a wide angle lens, you'll have to get closer, wihch will make the background seem smaller and farther away. You don't have to get as close with a longer lens, which will make the background seem larger and closer.
The aperture affects depth-of-field. If you're photographing something flat, like a piece of paper, you don't need much DoF. If you're photographing something three-dimensional, you'll need more DoF.
The exposure mode might depend on the lighting conditions and your personal preferences. I tend to do most of my close-up work in Manual. I also tend to focus manually, for better control.
There's no one set of "best" settings for close-up photography, any more than there's a set of "best" settings for any other type of photography.
Mar 30, 2010 | Nikon D80 Digital Camera with 18-135mm...
Hello, I have a lens error on my camera, the lens cannot close
lens cannot close,lens unit parts damaged,when u try u must be hearing some sound,so replace with a new lens unit
Mar 04, 2010 | Nikon COOLPIX S200 Digital Camera
Lens won't close
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Dec 27, 2009 | Nikon Coolpix L15 Digital Camera
The lens cover will not open and close all the way.
to open them completely simply push them with your finger. try doing so also when closing them. i have the same issue sometimes.
Jul 13, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
NIkon D60 - blury lens
for the close up photo u have to use micro or close lens set
Apr 25, 2009 | Nikon D70s Digital Camera
Lens won't close
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 17, 2009 | Canon PowerShot SD1000 Digital Camera
Lens does not close anymore -
When you opened it the cog connected to the motor which opens and closes the lens probably shifted and no longer has traction against the ring around the inside of the lens which turns it to open and close it. If you open the camera up again be extremely careful - the lens has loads of springs inside it - lose one of these and it won't work properly. I opened up the whole thing to try and fix my lens which had been jammed in after a friend dropped it. I fixed the lens but couldn't put the damn thing back together again to many tiny parts and no guide to the jigsaw!!
Nov 16, 2008 | Casio EX-Z1050 Digital Camera
Sony-DSC W1 lens not closing
batteries may be low. Dont force it unless its your only option. You could strip a gear.
Mar 02, 2008 | Cameras
Lens wont close
tryig to force it closed if sand is in it will do further damage. Can you gently extend the lens and jiggle it to see if any sand comes out. Most likely this fault needs repairing to open it up and remove the sand.
Feb 27, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Nikon Coolpix 2100 Digital Camera Logo
82 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
