Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
MY MFC-240C ISN'T WORKING
My scanner is stuck with a terrible noise. I can't install the cd either due to this. All it says "scanner unable AF". See troubleshooting and routine maintenance user's guide. Plse help me.
  • 832 Answers
You simply have to reconnect the flat cable of the scanner to the main pcb.
Therefore you have to open the mfc by opening the scanner cover as when you have a paperjam. Loose the the blue support by pressing down the clip on the right side and pushing the support to the right.
Disassemble the "Z"-forming by carefully pressing it up at the latches which can be seen. The flat cable has to be connected to the main pcb simply by sticking it into position :-)
Error will disappear.
Posted on Nov 08, 2007
MFC-240C printer head repair
mY MFC-240C PRINTER IS NOT PRINTING WITH A MESSAGE " UNABLE TO PRINT SEE TROUBLESHOOTING
Nov 11, 2009 | Brother MFC 240C All-In-One InkJet Printer
Scanner bar will not reset, error "unable to Init. AF"
the problem might be the connection from the mother board of the printer to the scanner maybe due to lost contact and the ribbon was broken you might just have to reconnect it or it might be broken and need replacement
May 10, 2009 | Office Equipment & Supplies
PRINTING...
Have you unplugged the printer for a few minutes to clear the memory ?
Jan 21, 2009 | Brother Multi-Function Center MFC-240C...
What is 'print unable 51' never had a paper jam!
Do the following:
Print Unable
XX
The machine has a mechanical
problem.
—OR—
A foreign objects such as a clip or
ripped paper is in the machine.
Open the scanner cover and remove any foreign
objects inside the machine. ( You might try cleaning the scanner glass.)
If the error message continues, disconnect the machine from
the power for several minutes and then reconnect it.
Try this and let me know what happens. Binary Bob
Nov 21, 2008 | Brother MFC 240C All-In-One InkJet Printer
Clean unable
Follow this LINK and rate me when you are done pls
May 02, 2008 | Brother Multi-Function Center MFC-240C...
Unable to Init AF - New printer!
sure (this advice costs you some greetings from me to the beloved bahamas ;-))
you have to open the scanner as you have done to connect the usb cable. When opened you can see a "z" like small cover going from panel to the right rear side.
Open this cover which hides the flat cable of the scanner. The cable needs reconnecting to the main board. Simply stick it carefully into the right positon.
(will post a picture later)
Apr 04, 2008 | Brother MFC-465CN InkJet Printer
MFC-240C
You have to reconnect the scannerflatcable to the main circuit board.
Open the scanner top as when a paperjam had occured. Remove the "Z" lookinglike plastic cover near the middle running to the right side which hides the flatcable. Simply stick the flatcable into the mainboard, close the cover
again and close the scanner top.
Feb 18, 2008 | Brother Multi-Function Center MFC-240C...
Error Message: Scan Unable A6
the scanner or main circuit board is defective. Give it back to dealer due to warranty.
Jan 12, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC-240C init. unable AF error message
Sure. No prob.
Open scanner cover as you would do to check for a paper jammed sheet.
Do open the plastic which runs from middle to the right side (looks like a "Z" turned clockwise). Use a small screw diver for that. beneath you will find th flat cable of the scanner. You have to reconnect the flat cable by simply sticking it into position onto the main circuit board. make sure flat cable is in good position and click the" Z  "onto the channel. Close cover then power up and do what ever you want to do with your mfc ;-)
Dec 12, 2007 | Brother MFC 240C All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
191 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
