Alphasonik PMA1000D Car Audio Amplifier
Problem for Alphasonik PMA1000D Car Audio Amplifier
Amp cutting out when bass hits
By dgregorywade on Jul 01, 2009
i have a alphasonik pma1000d amp hooked up to 2 splw-12 subs running at 1 ohm as recomended when the bass hits heavy it cuts out ive tried hooking them up one at a time and it still does it gains down boost down doesnt matter specs on amp says 2060 watts at 1 ohm rms subs are 1100 rms at 1 ohm ive even moved the ground 3 times and still doesnt help plus i have a 6.0 farad hooked up disconnected it to see if that helped but all problems still exist
Solution #1
posted on Jul 01, 2009
Not Rated)
ronaldo_ross
Rank: Wiz
Rating: 84%, 281 votes
make sure that all the connections to the power supply are tight. The protection circuit is doing this so that your amp do not burn up. The size of your amp also demand heavy wiring. Make sure you used the recommended size. Also you need to make sure that the battery and the alternator can keep up with its large demand. You may need an extra battery too. I know a single battery can deliver a lot of current, but a powerfull amp demands the current really fast, when the bass hits. You can use a large damping capacitor, they are extremely big, or you can add another battery. All these will also give your amp more thump, and make it operate at full efficiency. meaning even louder! If these do not solve the cutting out issue, you may have to turn down the gain down slightly. Every type of music do not deliver same amount of bass, hip hop music, and rap would require you to trim down the gain some. Bass is delivered at its best in moderation, too much and you end up with a rattle rather than solid bass. I have a 4,000 watts amp at home, I don't use it in my car. I got it rigged up as a house stereo. I bought it for a 100 bucks broken, and fixed it. I have worked with hundreds of car amps a before in a electronic shops, I also design small amps once in a while. I myself love those loud gadgets. Well hope it has been helfull. Goodluck.
Was this helpful?
Yes
No
Solution #2
Not Rated)
palaboy
Rank: Wiz  Car Audio & Electronics  Expert
Rating: 82%, 1194 votes
the trouble might be the power supply section of the amp, inside the unit, have it checked, use a multimeter look closely to watch how the voltage varies when turning the volume up
Was this helpful?
Yes
No
Solution #3
Not Rated)
professio101
Rank: Guru  Car Audio & Electronics  Expert
Rating: 87%, 94 votes
With an amp like that you can not pull enough power from you cars battery alone. That is why when it hits hard it drains the amps from your battery and you amplifier cuts out. The light on the amplifier most likely dims when the bass hits. You need to get a capacitor. They are easy to hook up on the main power wire. You can get one from http://phatcaraudio.com/capacitors.html or get a used one off ebay.com. Good luck
Was this helpful?
Yes
No
Popular Solutions for Alphasonik PMA1000D Car Audio
Questions and Unsolved Problems for Alphasonik PMA1000D Car Audio
Do you recommend Alphasonik PMA1000D Car Audio Amplifier?
Answer
Answer
how do i bypass my factory infinity amp in my 95 jeep grand cherokee limited so that my door... (More)
Answer
i have a sony xplod 1000 watt amp.ive had it hooked up for about 6 months it sounded great.this... (More)
Answer
amp turns from green to red on and off i checked all wiring
Answer
no sound from subs all fuses and connections good
Answer
it was playing fine for a month than it just did not play any more
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Alphasonik PMA1000D Car Audio...:
Top Car Amplifier Experts
Rank: Guru Guru
Solutions: 14880
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Car Amplifier Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
