Question about Microsoft Xbox 360 Console
Disc keeps ejecting
After a short timne the game disc ejects then just seems to reinsert the disc sometimes does this after 10 mins other times can play or a couple of hours
    Problem Solver:
  • 13 Answers
Sounds like your disc drive is malfunctioning. Honestly the only thing i could possibly think of is that the button for the disc drive could've gotten stuck and opens the 360 by any sudden movements.
Posted on Jul 02, 2009
  • Nottingham Jtags
    Nottingham Jtags Jul 27, 2012
    Honestly,why do some of you post these silly repplies,"the button for the disc drive could've gotten stuck".Really? Thats meant to help? Obviously thats "the only thing i could possibly think of " but ****! It could be the magnet,the drive belt,cross flash,bad flash,bad update,system "open tray" error.
Mine does that too but it is the slim version and every 5 min it makes a beeping noise like you pressed the open button but only ejects every once in a wile.
Just like you.
"after a short timne the game disc ejects then just seems to reinsert the disc sometimes does this after 10 mins other times can play or a couple of hours"
Posted on Jul 18, 2012
  • Clayton Jul 18, 2012
    Just like you.
The disc will not eject and the wii says to insert a disc
Try holding down the eject button for at least 10 seconds after turning on the console. If that doesn't work (or you've already tried that). Try the following steps.
1. Unplug Wii from power outlet.
2. Plug in Wii again.
3. Press power button.
4. Press Eject button for at least 10 seconds.
5. If the disc doesn't eject try holding down the power button for 10 seconds and then the eject button again.
If that fails then either return the console to exchange for a new one or contact Nintendo consumer support. Info follows:
Nintendo Consumer Service Contact Information:
Telephone: 1-800-255-3700
Email webform: http://www.nintendo.com/consumer/webform...
I wouldn't attempt to manually remove the disc (by trying to disassemble your Wii) as it may void your warranty. It could simply be a faulty console in which case Nintendo should replace it within 2 weeks (according to posts I've read). It seems to be a somewhat common problem.
If holding down the eject button doesn't work, there's really not much else you can do. Sometimes unplugging and replugging does the trick.
I've had problems with discs not ejecting and some combination of the steps I wrote above solved the problem.
It is possible that you inserted the disc incorrectly. That would account for the error message "Unable to read the disc" or "Disc could not be read." But it should've ejected on its own.
Before calling Nintendo Service you can also see if their Support site has any solutions. Try the link provided in the source.
Good luck.
Dec 29, 2010 | Nintendo Wii Console
I have a pioneer avicx1r and when i try to eject a disc it keeps on coming up with mechanism error
The problem is the disc. It is most likely warped. I had the same issue and I actually removed the unit from the dash still connected, tapped the top and pushed the eject button and out came the disc. I played a little longer and reinserted the disc and it showed the error again, tapped it and ejected it then tried another disc and no problem at all. I tried several and they all worked and every so often tried the original one and it showed error each time. It seems as though the fact it was warped it was catching the unit or a sensor was seeing it as a problem and not allowing it to eject. Hope this helps
Sep 20, 2009 | Pioneer AVIC-X1R CD Player
Wii game disc will not eject
you have three choices, 1. send it to get disc out, 2. take apart yourself or 3. keep pressing eject button till comes out, ( try laying it flat, on side and upside down).
http://www.wii-ftw.com/?page=disassembling_wii
Oct 24, 2008 | Nintendo Wii Console
Disc won't eject & stops working
your disc tray is jamming on an intermittent fault and when it does work it is recording each time the eject botton is being pressed so when your watching movies or playing games it tries to eject the disc tray and causes an automatic shutdown it will definately neet proffesionally repaired and should cost about 30-40 pounds and get a guarantee with it bacause these faults can come back to haunt you.
Oct 06, 2008 | Microsoft Xbox 360 Console
Wii
hello micky1965
Email webform:
| Nintendo - Customer Service | Contact Us! |
riz.
althought i have a guide for opening inside the wii.?
Apr 08, 2008 | Nintendo Wii Console
Game stuck inside of PS3
hi you could try holding down the eject button for over 10 seconds, it rests the disc drive. hope this helps
Jan 22, 2008 | Sony Playstation 3 (PS3) Console
PS3 Blu Ray Drive won't eject
open that **** up,have similar problem,mine was caused because of a sticker on a dvd, couldnt find my warranty,and force eject wouldnt work,i was afraid to open the bluray drive completely,just to the point where i could manually eject the disc and found a round sticky mark on the disc,the sticker is probably still in there,but keeping the ps3 horizontally seems to help,your problem however could involve with the thingies in the driver not being propperly alligned
Jan 20, 2008 | Sony Playstation 3 (PS3) Console
Wii console will not eject disk
I managed to eject a WII disc out manually very easily:
- Disconnect the drive
- You see the white plastic mechanism on your right side and the wheel connected to the motor
- turn the wheel towards the back side of the drive while pushing the half inch square plastic piece towards the left.
You will see the disc coming out while you are turning the wheel.
Nov 25, 2007 | Nintendo Wii Console
Jammed cd drive
  • Touch the eject button on the PLAYSTATION 3 system front for 10 seconds or longer to force the disc to eject. After removing and before reinserting a disc into the PLAYSTATION 3, turn off the system, and then turn on the system again to resume use.
  • If the disc cannot be inserted, you may need to send your system in for service, please click on the link below.
  • Aug 27, 2007 | Sony Playstation 3 (PS3) Console
    Microsoft Xbox 360 Console Logo
    422 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    marley mcelhinney
    Tre Elkins
    Martin Murray
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
