Question about Zyxel ZyAIR B-100 802.11b (AM5009004) Wireless Adapter
I have a zyxel router, after connecting to the laptop via wireless, sometime it cant load the webpage such as www.google.com. but the wireless signal there showing "Connected" with full tab. After once awhile, the google page can be loaded again. this situation keep repeated every once a while. My msn will always disconnect or i send out the message to my fren,my fren couldnt receive it. I play garena, it will disconnected from host everytime in every 30mins. What should i do?
  • denho87 Jul 01, 2009
    no solution?
    no solution?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 127 Answers
Well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Posted on Jul 16, 2009
I have a toshiba satellite laptop my router is a zyxel p660hw the laptop can connect wirelessly to the router and gets full network access but no internet connectivity i work in an office and there are...
what is the laptop's ip address when on wireless ? default gateway ? subnet mask ? when connected on wireless ?
what are these when connected to cat5 ethernet cable ?
Is the default gateway different ?
is the ip address within the network address ? 10.0.0.3 to 10.0.0.254 or 192.168.1.3 to 192.168.1.254 ?
the first three digits should the same
what is the wireless ip address is it the same as the network router or different ?
What is the dhcp leases are they conflicting with the main router and wi fi router ?
How many DHCP servers are there ?
Nov 16, 2017 | Zyxel Prestige 660HW Wireless Router...
I have zyxel p-600 series router and i managed to connect to internet via cable (wired).then internet works on my ubuntu 10.04 but only when i write sudo dhclient in terminal. then internet works but i...
when going wifi
you have to go to internet connections or options in the control panel and click on the LAN settings button
the wifi modem will have a security code on the back and the wifi connection area code
click on the found area code on the back of the modem then enter the security code
Jun 04, 2017 | Zyxel Prestige 600WH Wireless Router...
My Latitude D610 Dell laptop is not connecting to the internet via my ZyXel broadcom router. In fact, the laptop doesn't even recognize the router or show the router as an option when I click on "Available...
1. Connect your router via LAN.
2. On your internet type in 192.168.1.1
3. Type 1234 on the password screen.
4. Go on the Wireless LAN tab
5. Un-check the option for Hide SSID
Dec 22, 2009 | Dell Latitude D610 Laptop Computer -...
Laptop does not detect wireless from Zyxel 660 router
Dear! You will have to enable wireless conection to access the router and internet. Check your adapter settings and enable wireless conection. Your problem will be solved.
Thanks
Jul 28, 2009 | Zyxel Prestige 660HW Wireless Router...
Cannot see other computers on my Zyxel router network
Change Settings, Be sure they on the same domain & workgroup settings and they are all shared.
Feb 27, 2009 | Zyxel P660HW-D1 Router
I have zyxel nbg334w bought before xmas 08 can connect pc to internet with it but although wireless laptops and games consoles find it still wont connect i am connected to internet via virgin media...
Had the same problem connecting zyxel NGB334W to XBox 360. Other computers and devices would see the SSID but the XBox 360 would not. I had no luck talking to the techs at zyxel, they said it was incompatible with the wireless XBox device. Good news!!! This can be resolved. I went into the setup (192.168.1.1) / Wireless Lan / Advanced / Wireless Advanced Setup. Under the 802.11 mode set to 802.11b. Factory is 802.11b/g and this was not seen. Hope this helps you out.
Jan 30, 2009 | Zyxel Prestige 334 Router
Zyxel P660HW-D1 Router Problem
my modem and router were working well, and then my router has stopped working
Aug 16, 2008 | Zyxel P660HW-D1 Router
Zyxel p660hw
Check if you have a firewall
In your TCP/IP set it to auto detect
Dec 03, 2007 | Zyxel P660HW-D1 Router
Zyxel p660hw and g202 problem
I had an almost identical problem and contacted Tech support at Zyxel. They were excellent and the guy talked me through to a solution. The main issue related to 'Bandwith management' which defaults to active on the router configuration. Unset all three (Wan, Lan, Wlan) and see if it sorts out problem. Because of some other issues I did have to reset the router to start with and on the wireless client I unset 'Obtain IP address automatically' and used an IP address with the default gateway set to the router address. If this does not help, I would recommend talking to Zyxel Tech Support, the consultant I spoke to was brilliant.
Nov 22, 2007 | Zyxel P660HW-D1 Router
Zyxel ZyAIR B-100 802.11b (AM5009004) Wireless Adapter Logo
411 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
