Drum screeching when spinning? - Washing Machines
  • 232 Answers
Could have some change stuck at edge of drum or the under wire of a bra even a screw or nail in one of the holes in the drum or worse a bad bearing!
Posted on Jul 01, 2009
Frigidaire (LTF2940) Front Load Washer Makes screeching noise during spin cycle, drum does not spin
the belt is either loose or off the drum or the tensioner gave out...please rate me thank you
Aug 10, 2008 | Frigidaire Dryers
Whirlpool cabrio model # wtw5500xw1. Horrible screeching noise when it goes into spin, then shuts off
Since I don't have the service manual for this model- I'm unsure if this is a direct drive motor to transmission or belt driven through pulleys.
In first scenario motor bearing is shot
Belt driven model, belt is worn or derailed from pulley
3rd reason, clothes could be stuck between spin drum and tub assembly, causing the spin drum to jam.
Mar 16, 2015 | Whirlpool Washing Machines
Hi, I have a frigidaire front load washer, model FTF2140ESO, that is making a high pitched screeching noise when it enters into the final spin cycle. The noise ramps up in volume as the drum spins faster....
Some times screws can work their way out near the drum and rub against the drum causing the squeak. You might have to take off the back of the washer and see if there is anything loose contacting the drum.
Oct 16, 2013 | Washing Machines
Hotpoint Aquarius 1000 WM62 The drum makes a screeching noise when turning ? Any ideas ?
it could be drum bearings or even some thing that has got past the inner drum and is jamed inside hitting the drum when it turns,,,,could also be the motor bearings,,,,open the door and try lifting the inner drum up,,if there is any lift in it then the drum bearings are going,,this will also cause it to screem on spin speed
Dec 01, 2010 | Washing Machines
Screeching on spin. Kenmore 110.92284100 Extremely loud screeching noise on spin, drum turning very slowly, won't turn at all by hand, water completely drained out. Bad bearing locking up drum? Got a...
The spin clutch/brake assembly has failed; you must remove the agitator, tubs, bottom seal. then remove the transmission from the bottom; the spin clutch/ brake assembly is located around the transmission agitator shaft under the tub. not a job for the faint of heart; difficult fix; most people just replace the machine. an appliance parts store can get you the part and, give you instructions in replacement procedure if you wish to do this repair.
Apr 07, 2010 | Washing Machines
Whirlpool LSQ8543JQ0 makes screeching sounds when in spin cycle
Could be somthing in drum or drum bearings...could also be coin in pump..you need to check pump out only to seperate fault ..Good luck
Feb 17, 2010 | Washing Machines
WASHING MACHINE WILL NOT DRAIN OR SPIN .ALSO MAKING A SCREECHING NOISE WHEN IN USE AND WHEN ITS TRYING TO DRAIN OR SPIN AND SOME OF THE WASHING CYCLES DO NOT WORK ALSO WHEN IT TRY`S TO DRAIN OR SPIN THE...
There might be a wire or something stuck in between the two tubs. If you go down to where the hose hooks onto the pump, you might be able to reach in and grab it. Plus there is stuff maybe in pump as well.
Jan 13, 2010 | Washing Machines
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
119 people viewed this question
Top Washing Machines Experts
