Question about Sony Televison & Video
Sony big screen tv 57 inch kp57wv600 ghost picture on corners, can that be adjusted ?
  • 1,056 Answers
"ghost" are not television problem. This happens when a nearby structure "echoes" the signal from the station to your TV, there is nothing wrong with it.
Posted on Jul 01, 2009
Sony kp-57wv700 cannot adjust color or hue
if you have a big sub right against it it needs to be moved away as the magnets can affect the big screen picture.
Mar 30, 2012 | Sony KP-57WS500 57" Rear Projection...
Tv turns on but has a shadow around evrything
Do you have any speakers or magnets next to the tv? If so, that is not good.
It may be a convergance issue. Check to see if you have any adjustments on the back of your tv to adjust picture. If not, if may be a faulty capacitor that needs to be replaced
Jul 02, 2009 | Sony KP-57WS500 57" Rear Projection...
SONY KP57WV600-Turns Blue and then turns black leaving no picture
Blue picture tube in TV is bad and requires replacement by qualified TV tech.
Apr 29, 2009 | Sony KP-57HW40 57" Rear Projection...
Screen fades to blue.
The Blue SCREEN setting is too high. These adjustments are located inside the TV behind the front panel. There are two screws behind covers and then a wooden panel to remove to access the adjustments. The leftmost set are for BLUE, the middle are GREEN, and the right are RED. The top row are FOCUS and the bottom are SCREEN. Focus will focus/unfocus the tube and Screen will adjust the power of that tube (there are 3 tubes, one for each color). If Screen is adjusted too high, horizontal lines will appear (my TV had red lines, but I played around with the knobs and saw that it could happen on any of the colors). Additionally, if SCREEN is set even higher than that, the tube could go so high that it turns the whole screen that color (in your case, blue). If this happens the TV will shut down, probably due to either overheating or overvolting. To fix this issue, turn the appropriate SCREEN dial down until the lines go away. In your case, you want to turn the lower left dial down. Don't turn it too far down, if you turn it more than necessary the TV can give you an AKB error (noted by the STANDBY light flashing a sequence of 5 blinks).
Apr 02, 2009 | Sony KP-57WS500 57" Rear Projection...
Removing green crt
More than likely you don't have to replace the CRT. Go to this blog for instructions for how to fix the most common problems.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
At the bottom of the page there are comments from users. There are several users that explain how to take off the front panel and where things are located. The model KP57WV600 is different than the pictures in the blog, including the fact that the order of the red, green, and blue adjusters are different.
If you try it and it's not successful and you still want to try to replace the CRT yourself, google KP57WV600 service manual and you can buy it for $9.99 and download it right away.
I wish you well.
May 03, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony kp57wv600
· Sony Picture tube recall
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 29, 2008 | Sony KP-57WS500 57" Rear Projection...
My Hitachi Ultra Vision 50 inch big screen (projection) tv has a ghost look around everything. Please help me and tell me how to fix this at home. Thank You, Dustin Kellems
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 18, 2008 | Televison & Video
Convergence and picture problem.
convergence ic's
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
Blue tint screen in video mode
Jan 05, 2008 | Sony KP-57HW40 57" Rear Projection...
yes ,it sounds like screen adjustment or focus block, should be around $200- $325 to repair.
Sep 08, 2007 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
207 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
