Question about Ricoh Aficio 1022 All-In-One Laser Printer
Code E405 hi we have ricoh 5640 code E 405 what is this and how i solve the problem.
Ricoh aficio MP2000 ERROR code SC302.
https://printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20200&code=SC302
Ricoh Aficio 200 Error Codes
Ricoh Aficio 200 Error Codes Code:
Code
SC302
Description
Charge roller current leak
A charge roller current leak signal is detected.
Causes
• Charge roller damaged • Charge high voltage supply board defective • Poor connection of the PCU
Apr 18, 2018 | Ricoh Computers & Internet
How to solve this problem sc 302
Hi
I managed to find a list of Ricoh error codes with brief explanations of their causes here:
Ricoh copiers error code messages
This clearly identifies the problem as a laser motor problem - OR
Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) - OR
SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650
SC-303 Charge corona wire cleaner, disconnected or time out for printer.
All of these sound rather like an engineer requirement but you may be able to something with appropriate spares
Sep 25, 2014 | Ricoh Office Equipment & Supplies
I want code for unlocking my LG-E405 DUAL SIM
You can unlock your LG E405 here. Good customer support and good price.
Mar 29, 2013 | LG Optimus E405 White Unlocked 1GB 3.15 MP...
How to clear error code ?
Hi its depend on codes that you got the problem should solved then code disapear every code has a meaning
Oct 21, 2010 | Canon Office Equipment & Supplies
Ricoh af2027 please wait with a wrench no code
Hi that normaly indicates the there is something wrong with the HDD. open the back of the machine and unplug the HDD. Swith the machine on. If it turns on the HDD is faulty. The machine will work without the HDD but you will not be able to use the doc server. To fix the HDD plug it in to a PC and initilize it. (right click my computer, manage, disk management, right click on drive, initilize. Put it back in the machine.) Should solve the problem.
Apr 27, 2010 | Ricoh Aficio 1035 Copier
Hi I have Ricoh Alficio 2032 copier. There is C545 error message
I'm assuming it's SC545. It pertains to temp not being correct in the fuser. Possibly a thermistor, thermal fuse or lamps are bad. It's one of the codes that need to be troubleshot and replace whatever is needed before clearing the code. This is to prevent further damage to the machine. Thanks Colin
Jun 28, 2009 | Ricoh Office Equipment & Supplies
Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Jun 09, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio 1022 All-In-One Laser Printer Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
