Clean pump The display on the washing machine Whirlpool AWO3761 says FP and the light on clean pump flickers. I don;t have the manual. Could you help me with instructions please?
    Problem Solver:
  • 3 Answers
U can simply get the manual from whirlpool.co.uk to solve the pump issue as its quite a simple one
its just a matter of opening the drainage door and unscrewing the drain catcher make sure u got a bowl or saucepan there to catch any water
and that will solve your problem
Posted on Oct 13, 2009
  • 3,600 Answers
No you need the manual the pump hasa pin in it and needs to have the snap rings removed and the pump cleaned, this is from the bottom most likely where the water pump is.
Posted on Jul 01, 2009
  • 232 Answers
Front load washers have a catch basket befor the pump that is easly removed be hind the lower pannel allways un plug appliances be for removeing any covers sears and partselect have some diagrams that may help you will need the model #
Whirlpool 6th Sense displaying FP and clean pump is lit ! How do you clean pump ?
On the lower front panel is a small door which may be behind the kick panel. Behind this door is the drain filter.. Do not undo this filter till you have emptied the machine, as any water in the machine will flow from the pump, when opened.. Leaning the machine back against the wall will help contain what water is left in the machine..
Undo filter, check and clean.
Check that a coin or hairclip has not fouled pump impellers.
If the impeller has come away from the pump shaft, the pump motor needs to be replaced.. A tech should be called for this job!
Good luck....Nomess
Aug 04, 2010 | Washing Machines
My whirlpool washing machine won't spin. In the digital display it is saying FP
Hi
Remove pump and check the pump for any foreign objects which is stopping the impellor from turning.
hope this will help.
Thanks for contacting fixya.com
Oct 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWO3761
hi we have a whirlpool awo3761/5 when wash is selected it goes to start but then doorlock flashes a nowt happens, i have just replaced with new doorlock this morning and with fingers crossed tryed again it looked promising but doorlock started to flash again and nothing happens pls pls help
Sep 07, 2009 | Whirlpool Washing Machines
I have AWO3761 and increasingly frequently the clean pump light is lighting up and FP is diplayed during the wash cycle. The machine is still full of water so I empty it and take the filter out which is...
check your drain hose sometimes coins get through the filter and get into the hose also the pump may be bad the impeller sometimes break and it will not pump out the water
Jul 11, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool awo3761 how do i claen the pump
Remove the lower panel on the front of the washer. The pump will be just inside. Twist the pump knob to unscrew. Clean it. Replace it.
May 14, 2009 | Whirlpool Washing Machines
My washer gets so far then says fp
fp indicates a pump failiure so either clean the pump filter, or if the pump filter is clear then you will need to replace the pump as this is indication of a knackerd pump
Jan 24, 2009 | Whirlpool AWM5125/1 Front Load Washer
FP code appearing on lcd disply
remove pump and check pump for foreign objects stopping impellor turning, worked for me hope this helps
Dec 26, 2008 | Whirlpool AWM8143 Front Load Washer
Washing machine
whilpool awo/d 4305 light onclean pump can i do this myself
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool 6th sense awm8163 programes never stops now cannot get it to work at all
The pump is at the lower left of the front of the machine covered by a white plate. Use a bowl to catch any remaining water when opening the screw thread inside and then clean and replace. If it is truely beyond repair then a new filter pump can be bought from ebay for £3 or thereabouts.
I have just drained mine manually in this way and am going to run it empty with soda crystals to glean a few more days use whilst the new pump arrives.
Good luck :)
Jan 20, 2008 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
444 people viewed this question
Top Washing Machines Experts
