Question about GE (PSS26MSRSS) Side by Side Refrigerator
Making lot of ice
Our refrigerator is two years old and I think it is making lot of ice because inside ice box cannot hold the ice it get stuck and water also leake from the freezer on floor
  • 833 Answers
Re: making lot of ice
I'm going to guess that there is something jammed into the ice maker making it misbehave. Power it down and have a look. Most units remove for cleaning.
Posted on Dec 20, 2007
0 characters
3 Points
Ice maker ice jam
Not a whole lot you can do but to keep the frost down.
If you are able to move the items in the freezer to another freezer and let it sit overnight, all your problems will melt away....
Until a couple months later when it builds up
Make sure to double check your freezer is sealing correctly, bad gasket causes moisture to be sucked in.
Here are some basic ways to slow the buildup
How to Avoid Freezer Frost
Feb 10, 2016 | Samsung Refrigerators
Whirlpool Refrigerator water leak through Ice dispenser
You need to remove the ice maker and open the front carefully. It has small micro switches inside it and it sounds like one that opens the water control valve is stuck in the on position. Be careful not to loose the arm spring and how that goes back together as you take it apart. Sea Breeze
Sep 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Noise on the ice maker
I think you are having the same issue that I am having. My noise is being caused due to ice build up around the fan inside the freezer. There is a switch when you open the door that causes the fan to shut off, hence the reason the noise stops when you open the door.
I pulled the cover (just below the ice maker) and removed the ice that had built up. Only problem is that after three days the noise is back. I think there may be a bigger problem that is causing the ice to build up around the fan.
Jan 05, 2009 | Samsung RS2630WW Side by Side Refrigerator
GE Side by Side Ref
Sounds like an internal mounting spring for the compressor. Only solution is replacing the compressor. However the compressor can run in this condition for years. Replacement compressors only have a one year warranty. A new refrigerator comes with a five year warranty.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE profile refrg. with ice maker
Too much ice, maybe the ice maker didn't connect right, the gears moves but the spring inside the ice maker won't move.
Jul 08, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Side-By-Side Refrigerator Model GSS 23QSTA SS
Apparently the digital read out sensor is bad. 45°F is to high for safe food storage. The fact that the milk spoils is another factor which speaks on its own that there is a temperature control problem. There is no "defroster fan". There are two fans in the unit. One is the air circulation fan located inside the freezer compartment and the other is the condenser fan for cooling the refrigeration system. If you had called for service in the first year it would be covered by warranty with the exception of the service call charge. After the first year ends electrical and control problems are not covered. If the evaporator fan in the freezer is noisy there is something wrong with it. It could be the source of your whole problem.
Mar 27, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker broken
check to make sure the arm or what ever controls the cubes isn't stuck closed or the inlet to the maker isnt' got some restriction
Dec 08, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not making ice
Same thing happened to me. I unplugged the refrigerator, plugged it back in and it worked. I guess the computer system reset itself. Easy fix.
May 13, 2007 | Maytag MSD2756G Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
48 people viewed this question
Top Refrigerators Experts
Vish Iyer
Vish Iyer
Todd Marr
Todd Marr
John Tripp
John Tripp
