SOURCE: i have a toshiba regza mod# 42rv530u that my
could be tiling if it is like frozen squares it is probably a cable system problen not the tv
SOURCE: 42" Regza #42RV530U won't turn on. Was working
not being funny but have tried changing the fuse or the mains lead if it plugs in the t.v
SOURCE: Hi,Iwas watching TV and the
If there was a popping noise of any kind when the tv screen went black there's a high possibility that one of the fuses in the tv popped and there is no power to the tv. It could also just be the outlet itself and try plugging the tv to different working outlets.
SOURCE: Had my toshiba regza 42rv530u
try resting your tv. power off it press and hold av select botton and then power on your tv wait few minutes and it will rest your tv.... if not used the same wy holding menu botton instead.
SOURCE: service manual for a toshiba tv 42rv530u please anyone?
Send your email address to me. I've the service manual to your set, and I'll send a copy of it to you by retrun mail.
The 42RV530U is known to develop problems in both the power board and the main board.
You can check out our power board repair service at
http://www.coppelltvrepair.com/p/442/repair-service-for-toshiba-42rv530u-power-board-75010942-dead-tv-or-clicking-on-and-off-problem
and I'd also recommend that you search for 42RV530U at http://blog.coppelltvrepair.com as we will eventually release an article on how to test the board.
Hope this helps.
