Question about LG Heating & Cooling
How to set the time in lg plasma gold spilt ac
  • 400 Answers
Switch on remote. Open cover. Find 2nd function button (blue) Press this button then on and then follow through with time setting. After finish, press off set off time and then this should be setup.
Posted on Jul 02, 2009
Hello i have a lg 42pg6010 plasma tv and it will not turn on, got power and a stand by light but when you switch it on it trys to come on but nothing please help
Change the power supply board. Do a google, ebay or shopjimmy.com search with your model number for price and availibility. Be sure to match the numbers from your board to theirs. Take the back off the set and trace the power supply via the AC plug up wires.
Jun 28, 2011 | LG 42PG60 42 in. HD-Ready Plasma TV
We have LG spilt AC unit and the remote was last. if there is any setting in the AC unit for to ON the AC unit without remote?
There will be manual butting near the display. Lift the front cover and you can see. But no option to change mode or setting temp. It's strictly advisable to buy new remote.Thanks.
Feb 09, 2011 | LG LSC121PMA Split System Air Conditioner
I have a neo plasma LG air conditioner, i am having problems switching on to cooling, sometimes it works, other times it is just circulating the air, making the room hot, it is 4 yrs old.
Possible problem with the thermostat which might be sensing the wrong temperature and so is not switching ON the compressor. So if the AC works once it is ON then the gas and compressor seems good. So you must check the thermostat and control board. Set the AC to a lowest temp and try.
Jan 24, 2011 | LG Heating & Cooling
Have a AS18U samsung spilt AC which is giving out very bad odour..
just happened out of the blue or first time starting it this year
May 12, 2009 | Heating & Cooling
Lg Plasma Display settings keep switching
When you boot up your tv for the first time, you get to choose between home and shop-mode.
In your case, he TV is set to "shop-mode".
Then it will go back to factory settings after 5-10 minutes. (so that customers won't mess up the settings all the time)
So change the settings from shop to home, and your problem is fixed!
Jan 07, 2009 | LG 42LC2D 42 in. LCD HDTV
My LG plasma gold ac's remote controler
If you lift the flap on your indoor air con there is a Emergency operation button on your right you can operate the aircon from there. Push once for 20 cooling and twice for 22 heating
But sounds like you need a new remote. If you want to know how to test the remote please let me know
Hope that helps
Nov 16, 2008 | LG LS-L1210CL Mini Split Air Conditioner
LG Spilt A/C
medev,
there is a lot of reason why your LG split unit would not work by remote control.
first likely trouble is the remote itself. it could have drop from a height and broke the remote, or corrosion has set inside the remote if you left an old battery for a long time and it could have broken it.
secondly which is not more likely to happen is the remote receiver in your unit got broke that is why it can not communicate with your remote controller. it could happen if someone has serviced your evaporator and could have disconnected wires to the receiver , or wires were just left not connected.
you can test the remote if you have an identical unit which is working with a working remote. use the working remote to your unit then you can decide.
i hope i was able to help.
Jun 24, 2008 | LG LS-L1210CL Mini Split Air Conditioner
We can off the swing mode in spilt AC?
just click on the swing button if it is on it will turn off if it is off it will turn on but make sure u point the remote towards the ac
May 07, 2007 | Electrolux E23CS75SS Air Conditioner
Heating & Cooling Logo
1,587 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
