Question about Dell Dimension 4600 PC Desktop
Blank moitor my monitor goes blank when i turn on the computer (dimension 4600). I am not sure if it's the video card or the monitor. If it is the video card, what should I do to install a new one, and what kind should i buy? Thanks
  • janimama Nov 13, 2007
    when i turn my computer on the monitor turns on for 3 seconds and then shuts itself off - i have completely shut the system down and have also tried another monitor and it does the same thing - whats wrong - please help!
  • 310 Answers
Can you chk anything abt the lights on the monitor ? ie.. the small ones near the power switch .. is it green / orange ..
Also do u hear any beeps when you power on your computer ? I vaguely remember that in case you hear three beeps, it could be a video card issue.
- Ranjit
Posted on Nov 08, 2007
Dimension 4600 no display turn on. HD spins lights lite and can turn off no bios screen display
Change the VGA cable from the monitor, first but sounds like it's the video card that's failed. I would check the monitor with another computer to make sure it's not that.
Jun 03, 2014 | Dell Dimension 4600 PC Desktop
How to fix a no signal monitor ?
If you have a known-good video card and a known-good VGA cable connected, another possibility is that the monitor is defective
Jan 15, 2013 | Dell Dimension C521 PC Desktop
How do I replace the graphic card on a dell dimension 4600 desktop
open left side of computer (after shutting it down and disconnecting it)locate the graphics card, its the one your monitor connect to,disconnect monitor cable from board remove little screw holding card to back frame and ease card out replace with new one put it all back together and start pc up if it asks give it the software disk that comes with new card and follow the instructions.
Jul 06, 2010 | Dell Dimension 4600 Video Card (M9 TVT...
Will an Acer AL1716 monitor work with a Dell 4600? Do I need a monitor card?
It has video card already, just make sure the video card driver is correct. Mkae sure to set the PC video resolution to the native resolution of this Acer, which is 1280 x 1024 @60Hz.
May 10, 2010 | Acer AL1716 17" LCD Monitor
I want to put 4 monitors on my dell 4600
You need a video card capable of supporting four monitors. This is usually done with an SLI setup where the motherboard supports multiple video cards and each card supports two monitors instead of four, but the 4600 does not support SLI. Check out this link for a list of cards and methods that will work.
Apr 20, 2009 | Dell Dimension 4600 PC Desktop
Monitor and Mouse not working
GGGA indicates that the power on self test completed successfully.
GGGG indicates that the had off from the BIOS to the Windows Operating system was completed.
If you are not getting any video, and have an expansion video card, reseat the card. If you still don't have video, remove the card, and connect to the motherboard integrated video port (May have a black plastic cover on it)
Jul 16, 2008 | Dell Dimension 4600 PC Desktop
No video display
If the video card is built into the motherboard then try starting in safe mode and reinstalling the drivers from scratch. Download the latest drivers from the dell website. Safe mode will reduce the resolution and use a generic VGA driver. If your video card is plugged into a PCI slot try unplugging the video card and using a different slot and going through the same process. If you are still not getting any output to your monitor and you are positive the monitor is fine then you may need a new video card. To be sure, if the video card isn't embedded to the mother board, you could take it out and try it in a different computer. Hope that helps.
May 23, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600C
Check your bios settings to make sure your video settings are correct for whatever card you're using. It sounds like you have a conflict between an onboard video card, and an aftermarket card.
Feb 28, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600
when the screen goes away try to wigle the cable from the computer to the monitor see if it could be that
Dec 27, 2007 | Dell Dimension 4600 PC Desktop
Did you recently change or install a program that would affect the resolution and card output? Try booting into safe mode by holding the "shift" key during boot. From there right-click on the desktop and hit 'properties'-> 'display properties' -> 'settings' , check your resolution and drop it to 800x600 and then reboot. If everything goes back in normally make sure you have the right windows drivers for your video card. You can also check the driver version and settings while you're in safe mode. Sometimes the windows update drivers can act screwy and I would recommend getting them directly from your card manufacturer.
Aug 19, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
177 people viewed this question
Alun Cox
