Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My neighbor opens my door when they open theirs.
Is there a way to change the code to a different one on the opener ? Or how would I solve this problem.
    President:
  • 3,197 Answers
It all depends on the model number of your opener. Have you seen the neighbor open your door? Can you open his door? The odds against this actually happening are so great. Usually it is a bad wall control or the wiring leading to the wall control. You can temporarily eliminate both of these by removing the wire from terminal #1 on your motor unit. The remotes will still work with this removed.
Posted on Jul 01, 2009
Garage door opens randomly
Steve, If you have a remote door opener, change the code, as one of your neighbors may have their door using same code. Also make sure there is nothing hanging or blowing in front of sensor lights.
below are links, how to.
press the helpful button
How to Program Garage Door Remote Change the Battery Craftsman 315
Garage Door Help How to Program Your Garage Door Remote Control
How to Adjust Your Garage Door Opener Travel and Force
Feb 12, 2016 | Building Materials
Door opens randomly on its own!
can you change the toggle switches in the remote and door controller to a different code than it is set on now. Like the two devices must match but hopefully the neighbor code for their door will then be different. Also can you change the frequency ?
Nov 20, 2015 | Genie Garage Door. SilentMax 1000 3/4 HP...
Our Stanley 7200 professional garage door opener opens on its own. How to fix?
change the channel or code. It is set to a code that a neighbor is using. Yours is opening when they request theirs to do so. Next time, run outside and see who is just driving into their garage.
Sep 05, 2015 | Building Materials
I have a new car and I programmed the garage door opener in a car. Now when the neighbor presses his opener in him vehicle, my door also opens.
you may have similar net work codes
on the garage door company. but if their
compleatly different, i don't know.
Sep 06, 2013 | managemylife.com
I have a craftsman 139.53651 installed in 1994. It has the learn button for programming new remote codes. Reading through the manual and the Internet, there is no way to reset the code, it only stores one...
I think you are going to be stuck for a new opener. This is highly unusual but does happen. You are right about not being able to change the code. You can erase the codes but once you program it you have put the same codes back in. A new opener will be on a completely different radio frequency and should end this.
Feb 20, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door is opening when the neighbor open theirs with remot
You say you "setup the remote and the main box but doesn't solve." I think you mean you programmed the unit but I'm not sure. Anyway try holding the smart/learn button in for 10 seconds and this will erase the memory. None of the remotes should work. Now when you are sure the neighbor will not be using their opener, program your remotes. This may be what you did but I'm not sure.
Aug 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens/closes by neighbor
Your code may be teh same or close to you neighbors. I'd change to another code. Takes 5 minutes
Jul 19, 2009 | liftmaster Chamberlain Garage Door Opener...
Neighbor opening our garage door
Report this problem to the Manufactuer stating your model number of controller and remotes too and they may help solve your problem faster than getting offside with your neighbour,apart from that the remotes and motor controller may need replacing to give you more security and control over your own secure enviroment,
I have fitted many security devices,alarm panels,cameras,sensors,keypads,etc,
and never had to repair this type of fault as the supplier or manufactuer has always assisted with their products thru warantee or advice,
I have 20 years of experience in the industy in NZ,Thanks MISTERDJ
Jun 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens
Do you have the option to change the electronic codes on your garage door opener system? My father-in-law had the same problem a number of years ago. He had not reset the code (equivalent to the combination on a lock) from the equivalent of 0-0-0 (which his unit shipped with). Turned out that a neighbor (or neighbour - in Canada) had the same /similar unit and when the neighbor opened 'his' door, my father-in-law's door would also open. You don't have to see the person drive by - it can be the neighbors behind you as well. You may find a solution by determining if you can change the original electronic code to a different one of your own choosing.
Hope this helps.
Dec 31, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
233 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
