Question about GoVideo VR4940 DVD Player/VCR
Unit freezes after initializing DVD-RW brfore recording onto the disc.
  • God_Of_Spam Jul 07, 2008
    GOVIDEO VR4940 comes on, displays please wait makes an odd noise in the DVD side then turns off. Unit will not eject tape or DVD.
    DVD can be removed by opening the front pull-down cover then with a small object like a chop sitck press the slide lever on the right side of the disk tray. This releases the lock and you can pull the tray out.
    I'm still working on the tape problem. I'll post more as I find it.
Here is the contact info for GOVIDEO and for it's parent co. DPI. If the first does not get results write an open letter and after mailing the original to the CEO of DPI, post the letter everywhere you can. It does not always work but an open letter usually gets attention.
DPI, Inc., 900 N. 23rd St., St. Louis, MO 63106
t: 314.621.3314 f: 314.621.0869
DPI, Inc.
900 N. 23rd Street
St. Louis, MO 63106
Phone: 314.621.3314
Fax: 314.621.0869
Product and Accessories:
For general product information, email
For wholesale or distribution inquiries, email
Marketing / Public Relations:
For general marketing, communications and public relations information, email
For inquiries about DPI's Website, email
Posted on Jul 07, 2008
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
DVD/VHS Panasonic DMR ES30V.I have a "digibox which, via the Autotune facility, has input "Free to Air" stations. However,I can only record/replay digital channels 1 - 5.others e.g BBC4...
channels 1-5 gets signal from the digital receiver.
and the other channels are from the autotune facility connected to the TV ?
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Panasonic Televison & Video
The dvd wont initialize blanc discs so that i can record with it.i have used different disc as well
Do you mean it won't format/initialize the disc? Alternative possible problem, when you put in a disc, does it not recognize that a blank disc is in the unit? Only DVD-RAM discs need formatting. DVD-RW discs need to be initialized. DVD-R disc do not need either formatting or initializing. (This unit does not write to DVD+R or DVD+RW discs.)
In the case of DVD-RW discs that can't be initialized. Check if this has already been done (or if you need to unfinalize the disc).
If the new disc is not being recognized as a blank disc, the recorder may not be recognizing the disc (dirt, scratches or manufacturing issue) or the recorder is not focusing on the disc properly. In the first case, clean the disc or try a different type of disc (Samsung claims that their discs will be most compatible). In the second case, the unit may need service.
I hope this helps.
(usually tracking and focus problems will be seen on both recording and playback (even with commercial discs).)
Oct 30, 2010 | Samsung DVD-R155
My Samsung DVDR120 will not accept any new DVD-RW discs. I have tried Maxell, Memorex and SONY. They all either freeze at 85% initialization or formatting, or spit out saying system error. The machine is 4...
This is a common fault and usualy caused by the DVD drive going faulty, The Lazer changes angle as it records across the disc and at about 80% there is a change point.
I suggest putting a cleaner DVD through the unit before you try anything else as a bit of dust can cause that problem. If that doesn't fix it than you may need to change the DVD loader unit as a whole or as you suggested by a new modern unit with even more features.
Jul 16, 2010 | Samsung DVDR120 DVD Recorder
Can't Record DVD's
use a different format dvd disc. try -R or -RW
Nov 30, 2008 | Cyberhome CH-DVR1500 DVD Recorder
My recorder has stopped accepting NEW DVD-RW discs and ejects them. There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording I have tried...
I had the same problem. After trying several brands, the only one which is working perfectly is Maxell (yellow discs). I found them is the US (Seattle), have not seen them in France where I am leaving. Hope it can help !
Nov 08, 2008 | Pioneer DVR-5100H DVD Recorder
Loading DVD-RW discs
I have tried several different DVD-RW makes. Puzzling??
Nov 03, 2006 | Pioneer DVR-5100H DVD Recorder
GoVideo VR4940 DVD Player/VCR Logo
214 people viewed this question
Top GoVideo Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
