The tv will come on for 5 seccons then the bulb goes out and the 3 led on the front comes on no picture
  • 668 Answers
I would for the Lamp Fan to be bad as a guess.
Posted on Jul 01, 2009
LED screen comes on and goes black
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
LG LED TV has no picture (black screen) but still sound ...
Dec 09, 2015 | LG 47LS4500
TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
Feb 09, 2013 | Televison & Video
Problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture...
Lets try an error code operational checl. Unplug the tv and plug it back in. With the standby LED on press and hold the MENU and DEVICE/INPUT buttons for 5 seconds. The LED will flash a certain number of times pause for a while and blink again. Count the blinks before and after the pass, then post it here so that I can tell you what the problem is
Mar 27, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Sound but no picture
hi
i think its a colour wheel problem...if there is led blink tell me how many times it will blink i will sort if there is error code and i will tell the solution
Feb 14, 2009 | Sony Televison & Video
Hitachi 50V500, no picture ,sounds for about 15 sec.then goes off
I would try to re-seat the lamp. Pull the lamp out, check it to see if it may have gone bad again, then put it back in to make sure the contacts are connected. Before applying power, unplug the TV for 5 minute, and then plug in/turn it on.
Most lamps, if bad from the factory, will go out within 3 months of use. It does happen, and happens more often than you would think.
Try this, and see what happens. Good luck.
Jan 05, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
RCA P52937SG
Time to replace.
Mar 10, 2017 | Televison & Video
Ya...Ok
Good Day, egear00;
Did you try the DMD board? Other wise I'm still looking for solution.
big IRISH.
Aug 21, 2008 | Hitachi 60V500 60" Rear Projection...
JVC HD-52G786 shuts off
Do you have your TV plugged directly into the wall? You cannot plug into a power strip, it needs its own direct power source. Also, I have heard that there can be electrical problems inside. I have this same model, I love it, picture and sound. I just replaced the bulb for the first time last night. It was a little premature to replace it now but I know what caused it. I bought a new bulb and it works like a gem. If you ever need to change the bulb do it yourself. It takes maybe 2 minutes. The bulb looks like the Flux Copassitor and all you do is remove the door in the back on the side. Unscrew the the 2 screws that hold the bulb in and just pull out. When you put the new one in make sure you do NOT touch the glass on the new lamp. Just slid it in and screw the 2 screws back in and make sure the door is closed and tight. My uncle had a service guy do his and he got raked for 5-$600, The bulb costs about $200. Should last about 5-6 years at a rate of 5-6 hours of TV on time. Hope this helped. If not, sorry, but at least you know how to change the bulb. Good Luck!!!
Apr 07, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Samsung DLP HL-R-5667W lamp LED comes on solid, no picture, then turns off
DO you have the owners mannel if so read it and see what they would do ,have you removed the lamp and if so how did it look? some lamps only last for 5,000 hrs and others 8,000 hrs If lamp is bad TV will not come on.
Feb 20, 2008 | Samsung DLP HL-P5663W 56" TV
Vivitek tv
I have a 56" model that I have had a similar problem. My bulb burned out in <90 days. Warranty was 90 days on the bulb itself. When the TV picture goes out, the indicator LEDS blink on and off.
Here is what you have to determine:
1) First cover the left LED with a piece of paper so that you can't see it blinking. I don't know if your layout is the same as my TV. You may have to switch the paper blocking the LED.
2) Pay attention to the other LED and READ its' flashing code. In my case, the code was 2-3. It would flash 2 times, pause briefly, then flash 3 times. This meant code 23. That indicated the bulb was burned out.
3) If you look in the manual, It does have a code list of some sorts to tell you of the codes and their meanings. Hope this helps.
Nov 20, 2007 | Vivitek V37835 46 in. LCD Television
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
