Portable Air Conditioning unit no longer blows out cold air
We got a portable AC unit (9000 BTU) from Homebase about 3 years ago, we use it for about 5-6 months of the year (every year). Last night it stopped blowing out cold air - is there some kind of maintenance we need to do to it or is it goosed?
Many thanks
Rachel
  • Leigh Hunt
    Leigh Hunt Feb 14, 2016
    Also ensure it doesn't need draining - the black tube at bottom left (when viewed from back) can be moved down and opened to drain any excess water.
    New Friend:
Bit late I know, but for others having same issue, ensure that it doesn't need draining - use black tube at bottom left when viewed from behind to drain any excess water.
Portable Air Conditioning unit no longer blows out - 2_14_2016_4_40_12_am.jpg
Posted on Feb 14, 2016
    Scholar:
  • 86 Answers
Clean out the condenser fins with a vaccumn try this first. God Bless have a nice day.
Dickson
Posted on Jul 02, 2009
Excess water prodution in portable 14000 BTU unit. See below
all a/c units remove moisture from air with cooling coil being cold and room air blowing across coil - depends how humid it is - i have used several different portable units and this seems to be a common problem if it is humid
Jul 03, 2014 | Commercial-Cool 8,000 BTU Portable Air...
How do you add feron to lg lp0910wnr ac
I would suggest taking it to your local service shop. They can add the nedded service valve and add freon.
Jun 06, 2014 | LG Electronics LP0910WNR Portable Air...
Using as heater and unit is blowing cold air
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
Ac repair portable 12000 btu unit will not blow cold air
Maybe you have it set on dehumidifier mode instead of air conditioning mode. That happened to me with mine too. And turn off your timer (if it has one) or it will shut off after a while and you will forget why.
Jul 23, 2013 | Amana Portable Air Conditioner
Compressor only stays on for 2-3 minutes than shuts off
if the sensors are okay, it might be the compressor overheating, my portable ac (moretti elite ac) is also behaving the same, especially when i turn the fan to max. the compressor shuts down about 7 mins and turns on again in about 5 mins, now i found out when i turn to medium or low the compressor runs normally. i think when on medium or low setting some of the cool air directs/channels to the compressor thus cooling it more.
Jun 03, 2013 | Frigidaire FAP094P1Z Portable Air...
Sunbeam portable air condition..all things work..compressor runs..but now cold air sunbeam portable air conditoner mode KY25 ..9,000 btu I have it since 2005..I've used it for one year..it's been...
sometimes storing an AC for long periods of time will allow the coolant that it uses to seep out, leaving you with an AC that seems to work, but won'tr cool any air. If you have a user's manual (or can find one) check to see what type of coolant it uses (if it's freon or something else) and if you can refill it. If you can refill the coolant, that should resolve your problem ... if not, you might be able to take it to a repair shop and have them do it for you. Good luck!
May 29, 2011 | Sunbeam SCA082RPC1 Portable Air...
Amana Portable Electronic Air Conditioner 9000 BTU
Unfortunately I am unable to find the Manual in our system. Here is the information that you can use to contact them directly. They should be able to send you a new one.
Consumer Affairs Address:
7401 Security Way
Houston, TX 77040
To speak with a Heating and Air Conditioning Consumer Affairs Representative from within the United States, please call 1-877-254-4729
Jun 27, 2008 | Amana AP073M 20" Portable Air Conditioner...
Heating & Cooling Logo
726 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
