Question about Kenmore Refrigerators
Popping sound from the doors when open and close
I have Kenmore, side by side. The doors were taken off to be transported. After re-installing the doors, there is a popping sound coming off the fridge door. Sort of like a broken joint...
Thanks
Sasha
  • 232 Answers
Door cam broke off or got left off durring reassembly usually black plastic 2 parts 1 on door 1 on hinge some models require replacing the hole hinge put some silcone based lube on new ones
Posted on Jul 01, 2009
My Kenmore refrigerator side by side ice will not come out of door
Sounds like where the Ice comes out of the ice maker sometimes gets clogged with ice look inside that little Hopper the goes into the door and see if it has Cube's jammed in it
Jan 08, 2016 | Kenmore Side by Side Refrigerator
Switching a kenmore dryer door from right to left. I have taken off the door.. but it looks like I need to remove the plastic covering on the door to remove the hinge and install on the other side. There...
In General the deconstruction of the door is not needed. With a great deal of Kenmore dryers you can simply turn the door 180 degrees and reinstall it.
Aug 24, 2011 | Kenmore 85871 Electric Dryer
Our Kenmore side by side refrigerator(#106 5682 603) has developed an occasional knocking sound - fairly loud. I obtained a new water filter from "filtersfast.com" and have recently changed this filter...
If it sounds like it may be coming from the back of the freezer, it is the refrigerant "popping" as in feeds into the evaporator. Some models have this issue and there is a "fix" for it. (yours may not be this one though). Although the sound is annoying, it doesn't really hurt anything. That's not to say the icemaker isn't making the noise, or something else. But I am not sure where it is coming from.
Dec 31, 2009 | Kenmore 53642 / 53644 Side by Side...
Popping sound from drivers side door
if you were to remove the door panel and inspect inside, i think you'll find it cracked or broken. or maybe just needs to be greased up a bit.
Nov 22, 2008 | 1999 Jeep Grand Cherokee
Kenmore Refrigerator Freezing Up - Won't Defrost
i have a side by side kenmore frig freezer on th frig side the pop is freezing up and the water that comes out the door whtat could be wrong
Oct 12, 2008 | Refrigerators
Kenmore Coldspot not making ice
sounds like the flap that u can usually hear once the ice has stoppped coming out it sounds like a pop or thud ...what happens is the magnet goes bad and keeps the ice maker constantly open to the outside air causing ice melting and massive ice cubes.....usually a costly repair...check and lemme know
ps. id have a licenced repair guy check it out
Sep 30, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Right Door is making loud popping noise
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Sep 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Front cover of my kenmore dryer
Assuming the two top inside screws have been removed, grasp each side of the front panel, slightly tilt away from cabinet and lift up. (may have to rock back and forth a little)
Jun 15, 2008 | Kenmore 62602 Electric Dryer
Refrigerators Logo
93 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
