Smart drive 8 pride 5.5
It is very likely the water inlet valve is faulty. As I do not have the actual model number of your unit I would suggest you download this parts manual and check the actual part number of the valve for your model. GWxx and phase number. The location of the inlet valve is on the left side of the top console.
Hope this helps.
http://www.instructables.com/files/orig/FC9/GDMS/GLWR2CEL/FC9GDMSGLWR2CEL.pdf
Look at page 62 onwards in this manual to find out how to access the inlet valve etc. Make sure the mains power chord is taken out of the socket and the water inlet taps on the wall are shut before you work on the washer.
http://www.instructables.com/files/orig/F1I/XBIT/GLWR2CEQ/F1IXBITGLWR2CEQ.pdf
SOURCE: Our Fisher and Paykel Pride
Sounds like your pump is blocked. **UNPLUG the machine**. lift or drag the machine to a spot where you can let the water dump out. The water comes out fast and makes a big mess. Tilt the machine back. On the front-right underside of the machine you will see the pump with the fan hanging down. Unplug the white plug and the earth cable from the back of the pump. You might notice that there is a white plastic clip that you can move to the side. Hold the clip out and twist the pump clockwise. At this point the pump will drop out and water will go everywhere. Try and take the pump out kinda fast so that the coil does not get too wet while the water is dropping out. you might find a blockage (coil, hair clip, underwire etc) sticking out from where the pump impeller sits. Pull out your blockage and check that the pump spins freely when you spin it by hand. If it does not spin freely you need a new pump.
Now, after you unblock your pump, you can put it back together the same way you took it off. Make sure the white plug is not wet before plugging it into the pump and make sure the pump coil is dry too! use a blowdryer to dry for a minute if unsure. When twisting the pump back in, the wires should be at the back of the machine and the earth cable is kinda close to the rotor (motor). Make sure the pump is sitting flat so the seal works too. That clip should click lock back into place to hold the pump from turning. The washer will not spin until all the water is out in case you are wondering. Hope this helps!
SOURCE: Fisher & Paykel Pride 5.5 Smartdrive 8 not spining
There is a transmission clutch that engages for the spin cycle. A gear has worn or broken a tooth. Replacement of the transmission hispeed spin cycle assembly is required.
The other comments are of no use. You must get parts from an Authorized Fisher & Paykel dealer, or have an authorized repairman service the machine.
SOURCE: water drains but won't spin
please rate my suggestion...
SOURCE: have a Kenmore Elite HE4t
(just in case it's the following!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my comprehensive guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
