My laptop wont boot up at all..
My Accer 5310 wont boot up at all.. the fan engages for 5seconds then it stops completely. i have tried rebooting it leaving it.. but it just stops. i was using it then the screen went white, it wont turn on the power light is on but nothing helps. Can someone please point me in the right direction?
  • 1,056 Answers
Go to www.ubcd4win.com this is where you can download the sofware for free. save it to a disk and boot up you computer from a the cd drive.
Posted on Jul 01, 2009
My compaq presario cq60 wont turn on
Does the laptop boot? Sound? Do you see a "ghost Image" in the monitor in a bright light? If so, Could be backlighting, Inverter, on/off switch that shuts the monitor on/off when you open and close the lid. Can you boot to safe mode with networking? If so, Open the Device Manager, Uninstall the Graphics Adapter, reboot, the software will apply a generic driver, If the Graphics adapter has not failed completely.
Jan 24, 2013 | Compaq Presario CQ60-220US PC Laptop
My accer desk top won't boot up and an alarm is sounding
Alarm? Beep? Pull the AC plug, plug in , try again. Reseat the Memory Mods, replace CMOS battery. Need more info to give a informed solution. You didn'y supply your Model of Acer or OS? Take a look at Acer Support: http://support.acer.com/us/en/default.aspx
Dec 26, 2012 | Computers & Internet
12 short beeps and it wont stop rebooting
I'm not sure what 12 short beeps mean, but it indicates something is wrong with the hardware. Check your ram sticks. Found under a panel on the bottom of your laptop. If you have 2, take one out, try to boot, then swap them.
There are other reasons for beep codes, but they tend to be much worse & less likely.
Jul 23, 2012 | Acer Aspire Computers & Internet
When I plug the unit into power, the CPU fan runs very fast but no boot, and then when I press power on the fan slows down and the PC boots normally. It shuts down in about 30 minutes with no sign of...
Sounds like you are overheating. One way to tell if it's overheating is you say it will run for about 30 minutes then shuts down. When it shuts down try rebooting to see if the boots successfully. If it fails to boot successfully right after it shut down then you are probably overheating. If you wait awhile to let it cool down for 30 minutes or so and if you reboot and it does it successfully you definitely have a overheating problem. If I remember correctly all those compaq sr series have loud and fast running fans. Computers overheat because of three reasons for the most part: 1) A fan has stopped working. 2) The Thermal Paste on the CPU and Heat Sink has dried up or is not thick enough to keep the unit cool. 3) Dust has clogged the fan vents and inside the computer. Fortunately for you desktops don't have to be completely disassembled like laptops to get to the fan, CPU and heatsink. Just pop the case and you'll see the components attached to the motherboard
Mar 18, 2012 | HEWLETT-PACKARD Compaq Presario SR5518F...
My Netbook start but when the windows logo appears this come to freeze and I can't do nothing else. can you helpme what is the problem
First make sure that you have nothing plugged into your netbook like printer,camcoder,ipod, external hard drive. If you have any USB device plugged in to your netbook then unplug it and now try to boot your netbook.
if this does solve the issue. You can try step 2.
Step 2. Accer Factory restore.
Step 2 is only recommended if you do not have any important file or data or software in your computer. If you are ready loose your data then you can perform step 2.
All that you need to do is push the power button and as soon as you see your accer manufacturer logo start tapping on Alt+F10 and could stop tapping when you get the screen that says Windwos Loading Files after which you might get something that says Edit boot options then you need to hit the enter key.This would bring the Acer Recovery Management where you need to select completely restore system to factory settings and follow the on screen instructions selecting Yes/OK/Next and the process would complete in 30-45 minutes.
Mar 24, 2011 | Acer Aspire One Netbook 8.9" Notebook
Computer wont boot up
Take the battery out and try to boot the computer up with the external power supply.. If this works the the battery is shorted. If it doesn't then you will need to try another power supply, if that doesn't work then something internal has shorted in laptop
Feb 24, 2010 | Acer Aspire One PC Notebook
Reformet accer laptowindow corapetp Ihave NO cd Iweant purchase
Press "R" to go to the "Recovery Console while you boot the Windows".
Dec 24, 2009 | Acer Aspire 5610-4648 Notebook
Xp wont turned on it will not boot to the desk top it frezers
This should fix your problem. Even w/o your installation disk. I have used this program to fix Pc's I have picked up off the side of the road. I would hit the power button, it would show the BIOS then it would stop and shutdown. This fixed 99% of them I have picked up.
Go here
using a torrent program ie (utorrent, shareaza, etc) download SPINRITE.exe.
Burn this on a disk, the program is written with freedos included, but this will not work with 100% of laptops.
if the program stops and shows you a red screen with an error, use a program such as PowerISO to burn the disk and make it a bootable image by adding a .bif
after burning the program to disk-
  • insert disk and reboot
  • press any key to boot from cd if asked
  • when you see Prompt, change to your default cd drive.
  • type SPINRITE to start program
  • use recovery option 5
this may take a few hours or a few days depending on the condition of the HDD.
I have used this program to fix computers I've picked up on the side of the road. I would power it on, start to load then go into a loop. after running this program overnight I was able to reboot (after removing disk) and the pc started right up.
Make sure you run a program like Ccleaner (you can get at www.fileippo.com) to clean your registry2.gif and junk files after completion. ^_^
Sep 17, 2009 | Gateway MX6030 Notebook
Hp nc6000 wont bootup
hi thanks for using fixya!
On this kind of error, the only option you could do is to format your system, but if you are not so familiar in formatting your laptop, I suggest that you bring laptop to service tech, to easily perform error checking and reformatting. This error might be virus or software problems.
Thanks! hope this will enlighten you. please rate me! good luck!
Mar 18, 2009 | HP Compaq nc6000 Notebook
Booting problem in Compaq presario C700 laptop
With out looking at the machine personally I can only guess that there is a short of some sort that is bridging the pins the powerbutton is attached to. I'd get it cleaned.
Sep 04, 2008 | Compaq Presario 700 470024-192 Notebook
Open Questions:
Steps To Fix Toshiba Laptop virus and Freezes Issue Call toll free Number :+1888784-9316 Are you facing sudden pop-ups on your computer or witnessing slow loading of files and programs? If you are getting issues like slow internet and processing, unexpected computer behavior then contact Toshiba support for making your computer free from all such dangerous online threats. Toshiba support provides safe and secure removal of all virus and other infections along with protecting the system from any such instances further. Toshiba support providing technicians make sure that your pc is secure and also that all your important files and documents are safe from any type of harm. If your system is infected with viruses, Trojans or malware then it might show signs like slow computer processing and internet speed, unexpected computer behavior, sudden freezing and crashing down of the system, frequent arrival of error messages, many advertisement pop-ups, non-intended outgoing emails and messages to contacts, files disappearing, problems in hardware and accessory devices, screen freezing and image blurring issue etc. Toshiba support helps in scanning all the variants of virus inhibiting the system by using proper scanning process and removal processes after that. Many a times, user while scanning viruses on his system might not be able to remove all even after many attempts. This happens because system gets infected to new variant of virus due to vulnerabilities of programs used in that system or because of inefficient scanning methods. The anti-virus program used for scanning the presence of that virus might not have got that virus's signature. So, for proper and efficient scanning of all viruses and removal afterwards, it is necessary to take help from experts like Toshiba support technicians. These technicians utilize the efficiency of advanced techniques and much better tools to clean the system and make it infection proof in order to yield greater productivity. Specialists of Toshiba support collect samples of all the variants of new and recent viruses and update the user's software database with their signatures. In case your system is also suffering from the infection of any such viruses which is new and is creating trouble getting detected, then contact Toshiba support us for help on their toll-free Toshiba customer helpline number +1888784-9316 anytime for expert supervision and advice.
Aug 14, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
127 people viewed this question
Alun Cox
David Payne
David Payne
