Question about Shure (LX287CC) Professional Microphone
Radio Microphones. The antenna has broken off my microphone Shure SM58 Dynamic. just bought new mic few months ago but wanted to keep the two going, so can i get hold of a new aerial for it?it works on 173.800MHz VHF. it works with any wire but not as effective and I'm unsure whether I'm using a frequency that i shouldn't. many thanks.
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
See the following for repairs:
http://shure.custhelp.com/app/answers/detail/a_id/4053
Posted on Jul 27, 2014
night71
  • 328 Answers
SOURCE: feedback
That is a great mic. It has a lot to do with the room your in and acoustics of it. If you are too close to your PA or monitor, it will also feedback. Lowering treble and reverb will also help.
Posted on Nov 04, 2007
robotek
  • 1512 Answers
SOURCE: shure sm58
Hi danny
There not that much to take apart on the sm58. On page 2 of the user manual there is a wiring diagram to reconnect wires. the grill wind filter part screws on. The socket on the bottom is secured with a screw.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
Posted on Jul 04, 2008
  • 13 Answers
SOURCE: i cannot hear myself on the microphone shure sm58
What sort of a preamp are u using this needs to be plugged into the lo impedance XLR input (this is a lo output dynamic mic 1.85Mv out)
The XLR should be input pin 2 return (gnd) pin 3.This mic does not NOT use phantom power (48v) if it is a dual input (pin 1 48v) source make sure the phantom power is turned of.
If this is being done then there maybe a problem with the mic.
You can check this by plugging a source in to the input to check that it is working line out from cd player midi or some other source.
biinary 6
Posted on Sep 16, 2009
  • 211 Answers
SOURCE: re-solder shure sm58
If you're careful, you can solder it yourself.
Just solder some thin wires to the lose ends.
After soldering use some cellotape to isolate the solderingjoint and to attach the wires to the element.
If you're not familiar with soldering tiny things, please don't. Any technician can fix it for you.
Good luck,
Gerard
Posted on Mar 05, 2010
  • 417 Answers
SOURCE: shure sm58 mic stopped working ...
Check the wire connections where the xlr cable connects.
Posted on Apr 15, 2010
No sound from my sm58 mic
The SM58 is a very rugged and reliable microphone and there are not many things to go wrong with it.
Assuming that you have tried using a different cable / amplifier to issolat ethe problem to teh microphone itself the most likely things are.
  1. A wire has come off inside - gently unscrew the top of the mic - lift it off carefully lift because the wires inside are quite short.
  2. A broken capsule - this usually results from dropping the mic on hard surfaces. Replacement capsules can be bought quite cheaply.Just tak careful note of the wiring order before disconnecting the old one.
Feb 09, 2011 | Shure SM58 Professional Microphone
Shure SM58 not working. Tried on various pieces of equipment using various configurations of cables and not a sound. Took unit apart and all wiring appears to be intact. The mic has been unused for several...
The SM58 is a dynamic mic. It's actually a very simple device. Thus, it doesn't "degrade". If an SM58 fails, it usually fails catastrophically. Now, the problem for is that you don't know if the failure is in the handle (which includes a transformer) or the cartridge).
You can order a replacement cartridge from Shure and solder it in place, but might be better for you to just send the mic to Shure. I believe they will just replace the mic with a new one for their service fee.
www.shure.com/service
Nov 20, 2010 | Shure SM58 Professional Microphone
I have two Shure sm58 mics that simply will not work...I do not know where to begin. How should I trouble shot?
If these are wired SM58 mics, they will probably need to be sent to Shure for repairs. The cost to repair is less than purchasing a new one, and they will usually just send you a new mic.
Aug 28, 2010 | Shure SM58 Professional Microphone
Microphone cutting off
Ensure the battery in the mic is 100% - low batteries can cause all sorts of symptoms. I wouldn't recommend anything other than a well known brand of Alkaline battery and definatley not rechanrgables.
Jun 30, 2010 | Shure (LX287CC) Professional Microphone
What is name of battery cover on shure sm58?
If you have the regular 'ol sm58 hard wired mics, there are no batteries.
Mar 01, 2010 | Shure SM58 Professional Microphone
Small volatage at mic and pin 2 cable becomes open
If you don't have continuity of around 300 ohms or so between pins 2 and 3 there is either broken wiring within or the dynamic mic module is bad and requires replacement.
Feb 04, 2010 | Shure SM58 Professional Microphone
I cannot hear myself on the microphone shure sm58
biinary 6
Sep 16, 2009 | Shure SM58 Professional Microphone
Shure radio mic no sound
Call Shure Applications to help you troubleshoot at 800-516-2525, option 1. Have the wireless system and PA nearby when you call them.
Jun 04, 2009 | Shure SM58 Professional Microphone
Shure (LX287CC) Professional Microphone Logo
99 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
