When I start my car there is a odor coming from vents that smells like something burning and now my air conditioner stills blows, but only hot air. Help!
SOURCE: 2002 Chrysler Town & Country air conditioner
How do you know it needed freon, without gauges its hard to know, most people add freon because its not cold and that may not be the problem, in turn they cause more damage to the system,these vans are famous for leaks.check all the fuses,then jump the low preasure cycling switch and see if compressor truns on,youll need to look at the clutch to see it turn,then the next step is to check the lowside and highside preasures,
SOURCE: My air conditioner in my 2000 Chrysler LHS is
the orfice tube could be bad, that is a good place to start
SOURCE: BLOWING HOT AIR AND BURNING SMELL IN VAN, I WENT
you may have lost the main drive belt under the hood,serpentine belt} that would explain the hot air coming from vents,is it overheating? look to insure the drive belts on,with engine off. if the drive belts on,you may have a locked engine component,such as altenator,power steering unit,water pump pulley,idler pulley,the only way to tell for sure is to remove the serpentine belt and hand turn each pulley to insure they turn manually. suggest you do that. the burning smell may be coming from your main{serpentine}belt trying to turn on a locked pulley. thank you for choosing fixya.com!
SOURCE: chrysler 2002 sebring convertible air conditioner works part time.
ckeck your blower resistor and the connection
It is in the low side AC compressor hose.
