Question about Lanzar MXA422 Car Audio Amplifier
2000 watt american legacy amp protection ligh wont go off
I have a 2000 watt american legacy amp that worked for like 2 sec and smoked for a sec and then the protection light came on. the fuse never blew which is what i dont get, and now no matter what i do the protection light will NOT go off. i cant get the green power light to come on or get any sound out of it. im wondering is there anything i can do to fix it or am i just S.O.L on my investment and just be cheaper to buy another amp???? any help is greatly appreciated
Same thing happened to me so I returned it for repair turns out it was an internal 25amp fuse on the output. Got it back an it sounded very weak now it does not play at all. Nothing wrong with my setup as I have now got an 800watt amp that is running great.
Posted on Jun 12, 2011
I need to know the size of external fuses for a american legacy amp 2000 watt 2 channel 1990
25 to 30 amp fuses will work great, anything lower could possibly blow a fuse when a good bass note hits even if there is nothing wrong with the amp. Hope this helps.
Jul 09, 2010 | Legacy - American II: 2 Channel 2000W...
LA-1030 Protect Mode
you have an unloaded channel,so the voltage is exceeding what the protect circuit is supposed to see.you have to connect an 8 ohm resistor across the output of the unused channel.
do not drive a signal into it or you will smoke the resistor.
a 10 watt will do ok with zero signal input
May 23, 2009 | Legacy Audio LA1030 Car Audio Amplifier
My amp
My amp stays in protect mode i don't know whats wrong Any suggestions
Apr 05, 2009 | Legacy Audio American Legacy II LA1990 Car...
I have an american legacy series 2 1000watt apm
Check and see what size fuses it uses. Your watt power means nothing without good fuses. My suggestion would be to go buy 40a fuses and replace the ones you already have.
Feb 27, 2009 | Legacy Audio American Legacy II LA290 Car...
600w legacy amp
9 times out of 10 if your amplifire is in protect mode and evrything externaly, like speakers, fuse, voltage, etc. checks out fine then
either you have shorted out output transistors or power mosfet transistors. Basicly that just about what happens with car amps.
It's easy enough to fix IF, IF you know what your doing. First you
need to check the output transistors with a digital volt meter on diode check, If they check out then check your power supply mosfet transistors. I can almost guarantee this is your problem. Very common. I buy non working amps all the time and repair them. Listen to pbabin also he has helped me out. Good luck
Sep 08, 2008 | Legacy Audio American Legacy II LA490 Car...
What size fuse do i need for amp
start with a 50, may need to increase it if you are not using a large capacitor.
600 watts = 12x
x= 600 watts / 12 volts
x = 50 amps
Dec 13, 2007 | Legacy Audio American Legacy II LA490 Car...
Amp not working correctly goes into protection
Disconnect the speaker wires from the amplifier and see if it still goes into protection mode. If it still goes into protect with the speakers disconnected, there's a problem with the amp; if not, you may have a blown speaker or a shorted speaker wire.
Feb 22, 2007 | Legacy LA2098 Car Audio Amplifier
Lanzar MXA422 Car Audio Amplifier Logo
225 people viewed this question
Top Lanzar Car Audio & Video Experts
Chris Ward
xxxxxx xxx
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
