Question about Rolex Daytona 116520 Wrist Watch
How do you take remove the band off of a rolex watch
SOURCE:
  • 26 Answers
SOURCE: how to adjust leather rolex watch band
On the clasp of the watch. There are small holes ware the spring bar sits.
More current models do not have holes that go all the way through on the buckle but the spring bar still sits in between. With a small screw driver press in tward the middle of the strap ware the spring bar sits at the end of the leather strap. Pop out the strap and the spring bar and then place it into the slot that fits.
Posted on Jan 03, 2009
micromend
  • 748 Answers
SOURCE: Unable to Open Rolex Band [knockoff]
Hello
I bought one while on a buisness trip to China. I like the watch alot but the band was too big. I have a friend who's a jeweler. He fixed the band for free. It does take a special tool (which he had).
Posted on Aug 05, 2009
  • 2976 Answers
SOURCE: I had my Rolex watch serviced 2 years ago By Rolex and now
Either the stem or latch needs to be replaced. It's a common problem for ALL manual wind watches.
Posted on Dec 06, 2009
escapement
  • 2338 Answers
SOURCE: how do i open my rolex watch band
Do it hard way, as Rolex watch bracelets are very hard to open. Just use a bit of strength.
Posted on Jan 24, 2010
escapement
  • 2338 Answers
SOURCE: how do you adjust the band on a rolex watch
Unscrew bracelet screws from the side and take out/add link. Then screw bracelet screws back.
Posted on Jan 30, 2010
How do you take remove the metal band off of a rolex watch
Turn it over and get a small jewelers screwdriver and insert it onto the spring bar and lever it off ..look on YouTube for a video
Aug 16, 2014 | Rolex Daytona 116520 Wrist Watch
Where are serial nimbers located in rolex watches
Rolex case serial numbers are always stamped into the case beneath the bezel and you need to remove the watch band to read them...
May 21, 2014 | Rolex Daytona 116520 Wrist Watch
Where are the model number and serial number on a rolex
Thank you for contacting FixYa.
  • Look at the side of your watchcase. On the watchcase lugs, located where the watch bracelet is attached, you may see one small hole on each lug where the spring bar is located. This means your Rolex has the traditional pierced lug style. If your Rolex does not have the pierced lug style, turn the watch over, and look for the long spring bar in the space where the bracelet meets the watchcase. The spring bar attaches the bracelet to the watchcase. The directions for removing the spring bar on both watch styles is slightly different.
  • 2
    Use your thumb to press down on the link where the band meets the watchcase if your Rolex has the pierced lug style.. If your Rolex does not have pierced lugs, turn the Rolex over, and press down on the link where the band meets the case. Either way, you are applying gentle pressure to the same link, just different sides of it. Remember, you are only removing the side of the band at the bottom of the watch, so press on the link below the 6. Maintain gentle pressure on the link while performing the next step.
  • 3
    Insert the tip of your spring bar tool into the lug holes, and push the spring bar inward. When done correctly, you will feel the spring bar fall into the case, rather than pop back out. Repeat this step on the other side of the spring bar.
    For a nonpierced lug watch, place the tip of your spring bar tool on one edge of the spring bar, and push inward, until the spring bar falls into the case. Repeat this step on the other side of the spring bar.
  • 4
    Pull the band gently away from the watchcase. It should remove easily. You can now see the serial number on the watchcase.
  • The reference or model number of a Rolex is located between the lugs at the 12' position. It is also listed on the certificates Rolex issues.
    Hope this helps. Jewel
    Oct 07, 2010 | Rolex Oyster Perpetual Submariner Date...
    How do you adjust the band on a rolex watch
    Jan 29, 2010 | Rolex Day-Date President 118239 Wristwatch
    Hello
    Aug 05, 2009 | Rolex Day-Date President 118238 Wristwatch
    Changing a Rolex metal watchband to a leather watchband
    Put the watch face down and examine the point where the band is connected to the watch case. you will find two holes and through them you will see sprinbar ends insertyed into watch case lugs. Take the tiny screwdriver and push the springbar end inwards,then do the same at the other lug reaching them through those holes.
    Then repeat the same at the other end of the band.
    Measure the distance between watch case lugs- this will be exact size for your new leather band.
    Rate me, plesae.
    Mar 23, 2009 | Rolex Daytona 116528 Wrist Watch
    How do i use the watch band link tool i just got with no instruct
    Rolex is using screws instead of pins. Get the small screwdriver and unscrew the bracelet screws.
    Do not forget to rate, please.
    Feb 11, 2009 | Rolex Datejust SS
    How to remove links if there are no pins
    All Rolex watch bracelets has screws, not pins. Get small screwdriver and unscrew them.
    If there is no screws at all, that means bracelet links had been removed and you have shortest version allready ,or, this is not the real (genuine) Rolex bracelet.
    Find your nearest watchmaker to clarify all this.
    Jun 27, 2008 | Rolex Explorer II 16570 Wrist Watch
    How to open a ladies rolex watch band
    how to open rolex wrist band brand new watch
    Oct 03, 2007 | Watches
    Rolex Daytona 116520 Wrist Watch Logo
    83 people viewed this question
    Top Rolex Watches Experts
    Arturs Kalnins
    Arturs Kalnins
    Janelle Schoonover
    Janelle Schoonover
    Are you a Rolex Watch Expert? Answer questions, earn points and help others
