Question about HP Deskjet D4160 InkJet Photo Printer
HOW DO I POSITION 4X6 PHOTO PAPER IN PRINTER?
  • 341 Answers
Place the photo paper with the print side down all the way to the right and with the short side (4") towards the printer.
Posted on Jul 01, 2009
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
I want to print photos from my laptop onto four by six photo paper, and i loaded the photo tray with the paper, and changed the tray preference to photo tray, but it's still telling me that there's no...
You also need to change the paper type in printing preferences.You will find 4x6 and 4x6 with tab in th pull down menu where it says plain paper. Be sure to position the paper as far as it will go into the printer and close the paper controls to hold it there. Also fan it well before you put it in.
Dec 31, 2010 | HP Photosmart C5180 All-In-One InkJet...
How to load 4X6 photo paper Epson CX9400
as i know there's no 4x6 photo paper, u just load original photo paper than print on your photo with the size that u already edit. may be you should try software that usualy use to printing postcard like this
May 26, 2010 | Epson Stylus CX9400 Photo Printer
I can not get the 4x6 paper to feed into the printer during the printing process. the paper shoots through and the printer. screen says the paper is incorrect size. i am using kodak ultra premium photo...
Kindly place the paper in the photo paper tray and then place a photo on the scanner glass of the paper and press copy.Correspondingly,if you are printing from computer make sure that you select 4X6 in the printing properties or preferences while printing the pictures. Your issue will be solved.Keep me posted if you are facing any problems.
Dec 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Instructions on printing a 4 x 6 card or photo on my HP 4280 All in One printer. How to I set up the printer?
At the printer:
1. Remove any paper from the input tray
2. Put a few sheets of 4x6 (10 or so) in the same tray
3. Adjust the paper holder bar so that the 4x6 paper stays straight in place. The holder bar was holding the 8x11 paper in place.
On the computer:
Open a picture
Seect [File] [Print]
Select the photo printer from the list
Cick on [Preferences]
See the paper type? select photo paper
See the paper size? Select 4x6
Quality (Best)
[OK]
[PRINT]
Sep 28, 2009 | HP Office Equipment & Supplies
Using attachment to print 4x6 photos
The usual cause of this problem is too much 8 1/2 by 11 inch paper in the normal feed slot. Take most or all of the regular paper out of the tray before setting the photo feeder onto the front of the paper slot. When installing the photo feeder, make sure the photo paper container is extended by turning the big dial to the 2 o'clock position, then rotate the dial to the 10 o'clock position after the feeder is in position. Don't overfill either the photo feeder or the regular paper tray. It's pretty fussy about position and fit of the paper in the photo feeder.
Feb 21, 2009 | Canon i860 InkJet Photo Printer
Printing photos
Of course you can use 4x6 photo paper
you have select the paper size from page setup as 4x6
and put the paper in the tray after adjusting the tray size
Dec 27, 2007 | Samsung CLP 300 Laser Printer
Printer will not print on photo paper
Go into you printer on the control panel select properties> advance button and chose 4X6 and make it letter
Dec 04, 2007 | HP Photosmart C5180 All-In-One InkJet...
HP Deskjet D4160 InkJet Photo Printer Logo
141 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
