Question about Nokia Cell Phones
BH-101 echo problem
I have a Nokia 6300 mobile with BH-101 bluetooth headset. When i take a call with bluetooth headset, the person on other side hears an echo of his own voice. Its so problamatic.
How can i fix this?? :(
Nokia bluetooth head set BH-105 can't conect with my nokia C6 mobile
1: SWITCH ON THE BLUETOOTH FUNCTION ON YOUR MOBILE 2: THEN CHANGE MY PHOES VISIBLITY FROM HIDDEN TO SHOWN TO ALL 3; MAKE SURE U HAVE PRESSED THE BLUETOOTH HEADSET SWITCH ON BUTTON FOR AT LEAST 10 SECONDS . 3: U WILL HEAR A BEEP SOUND WHEN THE HEADSET IS SEARCHING FOR PAIRING 4 NOW SEARCH FOR NEW DEVICES ON YOUR MOBILE 5 WHEN THE SEARCH COMPLETES IT WILL SHOW BH-105 6 : SELECT IT AND CLICK PAIR . FINISHED
Jan 26, 2012 | Nokia Bluetooth Headset BH105
I have Nokia 5130c, it can not identify to pair with my Bluetooth BH-101
Try to remove all the paired deviceson your phone, then make sure bluetooth is switched on i.e on your phone, then switch of the bluetooth headset and try switching it back on when its on it should show a flashing blue light on the side o on the top, when its sflashing search for new devices on you fone, if its recongised and asks you for a key type four zeros (0000), this should work
Regards
Egroeg
Mar 24, 2011 | Nokia BH-101 BLUETOOTH HEADSET
Nokia BH-101 Not Pairing with Playstation 3
Consult user manual for how to put device into pair mode, then search under bluetooth settings on ps3 if prompted enter pin code 0000. If this does not work consult usuer manual for how to do a reset on the device, it should then automatically go into pair mode. From there search and pair.
Rylan
Dec 17, 2010 | Nokia BH-101 BLUETOOTH HEADSET
I've just bought a Nokia Bluetooth headset BH-503, using it with Nokia 6300 phone. The person I'm calling says he hears terrible echo, but I hear fine
Check where your phone is during the conversation. Even if it is written that Bluetooth works fine up to 10m I usually have problems when phone is in the pocket on the other body side that my headset receiver.
Jun 02, 2010 | Nokia BH-501 Headset
I get a nokia 5800 xpress music mobile before i connect it to nokia bh-604 bluetooth headset and its was fine then i downloaded new software to my mobile i tried to connect it with nokia bh-604 and my...
the problem was the bluetooth headset was already registered with a mobile phone ,first format your bluetooth headset by long pressing + button and power button or long pressing the poer button
Mar 17, 2010 | Nokia BH-604 Bluetooth Headset
Need a passcode to pair nokia BH-101 blutooth to phone lost passcode
If you haven't actually manually changed it, the password is always the last four digits of your phone number (ex. 1-555-868-2212 your password is 2212). If you manually changed it, you need to call Verizon and have that worked out.
-CompDoctor
Mar 02, 2010 | Nokia BH-101 BLUETOOTH HEADSET
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
How to connect LG cookie with Nokia Bluetooth BH 101
Put your Nokia Bluetooth BH 101 into pairing mode - this is normally done by pressing and holding the power key for several seconds. An alternate bleep will sound with a flash light to indicate that you are in pairing mode.
Now using your Cookie, press Menu > Settings > Bluetooth > Search
Your Cookie will find the Nokia BH101 bluetooth headset and then it will ask for a pass code. This is usually four zeros (0000).
You should now be connected!
Apr 10, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Cell Phones Logo
256 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
