Question about Electrolux Dishwashers
Dishwasher will not go through complete cycle it will not take water away
  • 133 Answers
Most washing machines nowadays have a electrically operated switch that will open to either drain or let in water if ur machine does not drain the water the machine will not go ahead in completing its cycle as the sensors sense that there is water in the drum so unless the water drains u will have this problem. Check for a click sound when the machine reaches a point to drain if that doesn't happen then it is this drain switch that isn't working
Posted on Jul 01, 2009
  • 641 Answers
SOURCE: Water Will not Drain
It could be cause the water level switch. The level switch is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine,but if you will open the rear panel you will find it easily. Clear tube from any obstruction. Good luck !
Posted on Jul 27, 2007
aborcass
  • 2651 Answers
SOURCE: dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
Skill Will
  • 53 Answers
SOURCE: I have a Blanco Dishwasher
hi, there are 2 pumps on a dishwasher, it sounds like the drain pump on your unit is not working, it may need to be replaced. . if it is in warranty contact the manufacturer, if not contact a local appliance repair company. in the mean time you can use a wet/dry vac to get the remaining water out of the unit.
Posted on Mar 21, 2008
SOURCE: beko dishwasher fills with water, does not wash but will drain the water away
impellor buggered. Needs replacing
Posted on Apr 12, 2008
  • 276 Answers
SOURCE: water in the dishwasher after the the cycle is complete
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Posted on Nov 19, 2008
Dishwasher does not complete cycle
Does it have standing water after cycle? If so you can turn the knob until you hear the water kick into the sink. let it drain this way completely and stop the dishwasher before it starts to add more water. turn the dial or switch to its off location and the let the dishwasher cycle completely to ensure issue is solved. Your dish washer is "short cycling". This usually works 9 of 10 times
Oct 28, 2013 | Dishwashers
Smeg DI 409CA Dishwasher - Doesn't wash properly, tablet doesn't desolve and cycle lasted all night
The first thing is have a look at the instruction manual from HERE
If the dishwasher is not washing properly then please follow these steps:
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
As you said that the water builds up at the bottom see If it comes out 'foamy' then liquid dish soap is getting introduced into the dishwasher. Liquid dish soap is different than automatic dishwasher detergent. liquid dish soap needs to be COMPLETELY rinsed from anything that has been pre-soaked prior to putting in the dishwasher. after a couple of regular cycles the foam will go away. Nowadays liquid dish soap is also 'concentrated' or 'ultra concentrated' which doesn't help.
If further this does not solve your problem the the only solution is to get it repaired.
Goodluck..
Feb 23, 2008 | Dishwashers
Dishwasher cycle never completes
This is a very common complait about dishwashers taking a very long time to complete cycles. More than not if you start your dishwasher cycle wait untill your washer fills with water. Reach in and feel the temp. of the water. If it is cold the dishwasher try's to heat the water. Most of the dishwashers are not design to heat water. And here is the delay. Try to run the water at your sink first until it is hot, Star your dishwasher and see if the cycle runs correctly.
http://www.on-timeapplianceplano.com
Jul 23, 2012 | Dishwashers
Water keeps running and does not appear to get hot. Cycle does not complete
The heater in the dishwasher might be faulty. Try running a quick cycle which does not heat water and check if the problem goes away.
The heater element can be found here.
Jul 28, 2011 | Neff 24 in. S5453X1 Built-in Dishwasher
Kitchenaid - water suppy not feeding
The water valve is either clogged or burned out. Easiest to check is whether it is burned out. Turn off power, remove kick panel, find where incoming water supply pipe attachs to valve and remove both wires to valve. Zero your ohmmeter and check for continuity across terminals. If it has continuity, valve is good. Use test meter to check for voltage from timer. Connect test meter leads to wires you removed, restore power, close door and put timer, or control panel, to where dishwasher should start filling. If there is 110 volts at the wires to the water valve, the valve is clogged. If there is no voltage, the timer or control is bad and must be replaced.
Feb 20, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Running time of dishwasher
he cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing See "The cycle doesn't complete" section.
The cycle doesn't complete If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Mar 14, 2009 | Bosch Dishwashers
Frigidaire dishwasher not completing cycle.
hi,
Water-heating cycle
Timer
Water-heating cycle
Timer
I see an error code
If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Good Luck
Thanks for using FixYa
Jan 03, 2009 | Dishwashers
Dishwashers Logo
472 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
