Question about Philips GoGear HDD6330 MP3 Player
It switched off automatically after short time & if want to start again need to press reset button
  • 24 Answers
See in the settings menu if the sleep-timer isn't set to shut it off. How is your battery's condition?
Posted on Jul 13, 2009
Need to set just the time on a timex WR100M mens watch
SETTING
  1. First, find the regular time mode by pressing the MODE button until the time (with the date at the top) shows.
  2. Press & hold the SET button until the word ENTER disappears and is replaced by the word TIME. Release that button. You'll notice that at the top of the display, the words SET T1 or SET - T2. This is where you select between setting the 1st time zone or the 2nd time zone. Select between T1 or T2 by pressing the RECALL button or the STOP/RESET button.
  3. Press either the MODE or the START/SPLIT button. You'll notice that whatever is blinking is what you can change. You can make the changes by pressing either the RECALL or the STOP/RESET button. You can change the Seconds, the Hours, the Minutes, the Month, the Date, the Year, and choose between 12 hour (civilian) or 24 hour (military) time. If you keep MODE or START/SPLIT button, you will go through all the things you can change and start again at the beginning. The START/SPLIT button goes through these things forward, and the MODE goes through the backwards, so if you pass something and want to back up, just switch buttons. In the same way, the RECALL changes things by making them larger, and STOP/RESET changes them by making them smaller, so if you accidentally pass the number you're trying to set it to, just switch to the other button and go back.
EXAMPLE OF SETTING THE WATCH Suppose you want to set the hours and the date in the 2nd Time Zone. (Just as an example, but setting any other time or date settings would be the same.)
  1. Press the lower left button on the side (MODE) until you see the date & time.
  2. Press & hold the lower right button on the side (SET) until the word TIME appears on the display, then release it.
  3. If SET T1 is showing, then press & release the upper right button on the side (RECALL) to change it to T2 (because we're wanting to set the 2nd Time Zone we'd leave this unchanged if we wanted to set the 1st time zone, T1.)
  4. Press & release the lower right button on the face (START/SPLIT) twice, skipping the seconds. You should see the hours flashing.
  5. Press & release the upper right button on the side (RECALL) repeatedly until you have the hours position set to what you want it to be. If you pass the hour you want, go to the lower left button on the face (STOP/RESET) and press & release it to back up.
  6. Press & release the lower right button on the face (START/SPLIT) three times, skipping minutes and months, so that the date begins flashing. Press the RECALL button until you have the date you want. (You can go backwards by pressing the STOP/RESET.)
  7. When you're done, and you've set everything you want to, press & release the SET button once to tell the watch you're through setting and to lock those settings in.
Nov 23, 2015 | Timex Ironman Watches
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
Oct 04, 2014 | Kenneth Cole Unlisted Ana-Digi watch
How to set time on my echo-7 cyclo computer, this is the older type echo-7 not f7, and it has 1 function button colored yellow at the bottom and you access all ..odo dst rt clk ..etc.
Hi, I got the same cyclo computer. Put the cyclo with the yellow button on the clock (CLK). Press shortly the reset button on the backside. The hour digit starts to flash. You can adjust the hour by shortly pressing the yellow button. If you want to switch to minutes hold the yellow button until the minutes starts to flash. When done press again shortly the reset button on the backside. When pressing the reset button the cyclo will start at zero seconds.
Bob
Mar 13, 2012 | Cycling
I am getting this message: WASTE NEAR FULL The waste ink tank* (which holds the ink used for print head cleaning) is nearly full. How can I fix it - the model is a Canon PixaMP110
One of these will reset the message. I reset mine about 2 years ago and have had no need to replace or clean the waste pad.
#1
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
#2
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Jul 23, 2011 | Canon Office Equipment & Supplies
Can you help i have the asda rch7h10 smart price remote controls and have lost the insrutions i changed the battries and now they need re programing
Switch the TV on.
Press the Set and TV buttons together and the red LED should light continuously. Then press the power button and then press it every time the LED flashes (about once a second).
When the TV switches off, press the TV button on the remote. Switch the TV on with the remote and check that the other buttons work as expected. If not, repeat the process...
I had the same problem: worked it out by trial and error ;-) Hope it helps...
Oct 28, 2010 | Televison & Video
I bought the water resist watch from walmart this evening it doesnt have a name brand on the watch but i think its a casio but it didnt come with the instructions on how to use it, the number on the back...
Thank you for contacting FixYa.
  • There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
  • 2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
  • 3 Press the start button to change minutes.
  • 4 Press the reset button again to switch to hours. You will know it worked when the hour starts blinking instead of the minutes.
  • 5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
  • 6 Press the reset button to switch to the date, starting with the month, and press start to change it.
  • 7 Press reset one last time to switch from month to the day, and again press the start button to switch days.
  • 8 Press the mode button to finish the changes.
  • Sep 14, 2010 | Watches
    My o2 xda stealth phone hanged b coz of virus help me out m not having setup cd wanna format my cell
    First of all switched offf this cell u can remove its battery & put it again then wait for a 10second then do this magic
    PRESS !<< & >>! & same time Press Power switch {left button in centre jog dial + right button in centre jog dial + Power Switch} & wait for a munit u ill see on screen formating at this time press Green Button thats is call button & this ill hard reset your O2 xda stealth
    Mar 18, 2010 | O2 Xda Stealth Smartphone
    SAMSUNG LE32R73BDX/XEU TV Digital TV Stuck on bbc1, no access to DTV menu to reset or retune. Sometimes picture is frozen, always it shows BBC banner and Mono. Standby - Info - menu - Mute - Power is not...
    just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
    Sep 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
    I have a Starter Brand Watch that did not come with a manual. I can't seem to get the chime to stop chiming on the hour.
    Just bought a STARTER Sport Watch Model# STW14 @Walmart
    TO CHANGE TIME:
    1. Press and release MODE button quickly 3X in a row(top middle no.(Seconds will flash)& change Seconds by pressing START button 2. Press & release RESET button 1X quickly(Minutes will flash) & you change Minutes by pressing START button 3.Press & release RESET button 1X quickly(Hour will flash) & you change Hour by pressing START button. 4.Press & release RESET button 1X quickly(Date will flash) & you change Date by pressing START button.5.Press & release RESET button 1X quickly(Month will flash) & you change Month by pressing START button 6. Press & release RESET button 1X quickly(Day of week will flash) & you change Day by pressing START button 7. Press & release MODE button 1X quickly to return to Normal use
    TO SET ALARM: 1. Press and release MODE button quickly 2X in a row(Hour will flash)& you change Hour by pressing START button 2.Press and release RESET button quickly 1X (Minutes will flash)& you change Minute by pressing START button 3. Press & release MODE button 1X quickly to return to Normal use
    TO VIEW MONTH & DAY: 1. Press & Hold START button 2.Just Release START button to return to normal use.
    TO USE STOP WATCH: 1. Press and Release MODE button quickly 1X 2. To START stop watch: Press START 1X quickly 3. To STOP Stop watch: Press Reset button 1X quickly 4. To RESET Stop watch: Press & Hold START button and press RESET button quickly @ the same time, 2X in a row 5.Press & Release MODE button 1X quickly to return to Normal use
    Sep 12, 2009 | Bulova Watch
    How do you set the clock nissa versa 08
    Clock set
    If the clock is not displayed with the ignition
    switch in the ACC or ON position, you need to
    select the CLK-ON mode. Press the MENU button
    repeatedly until CLK-OFF mode is displayed.
    Use the TUNE/SEEK button to enable CLK-ON
    mode.
    1. Press the MENU button repeatedly until
    CLK-ON mode appears.
    2. Press the MENU button again, the time will
    start flashing.
    3. Press the TUNE/SEEK button
    or to adjust the hour.
    4. Press the MENU button again; the display
    will switch to the minute adjustment mode.
    5. The minutes will start flashing. Press
    TUNE/SEEK button or to adjust
    the minutes.
    6. Press the MENU button again to exit the
    clock set mode.
    The display will return to the regular clock display
    after 10 seconds, or press the MENU button
    again to return to the regular clock display.
    Resetting the time
    Hold the MENU button down and then press the
    TUNE/SEEK button, the time will reset as follows:
    c If the displayed minutes before the reset are
    in the range of :00 - :29, the hour displayed
    before the reset will stay the same and the
    minutes will be reset to :00.
    in the range of :30 - :59, the hour displayed
    before the reset will advance by one hour
    and the minutes will be reset to :00.
    For example, if the MENU button and the
    TUNE/SEEK button are pressed while the time
    displayed is between 8:00 and 8:29, the display
    will be reset to 8:00. If the buttons were pressed
    while the time was between 8:30 and 8:59, the
    display will be reset to 9:00. At the same time the
    display will return to the audio.
    Nov 11, 2008 | 2008 Nissan Versa
    Philips GoGear HDD6330 MP3 Player Logo
    44 people viewed this question
    Top Philips Audio Players & Recorders Experts
    Gyula Lacz
     Grubhead
    Grubhead
    Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
