Brushes turn but have no power, They stop as soon as it touches the floor?
SOURCE: bare floor attachment for Hoover steam vac with surge clean
According to www.vacuumpartstore.com, for model #'s F5903, 5904, 5905, 5906, 5910, 5912, 5914, and 5915, you need Hoover SteamVac Bare Floor Cleaning Attachment (old # 48417003). You can get it at www.amazon.com for $7.99.
SOURCE: Hoover Steam Vac - Brushes not turned, no suction power
The Brushes not spinning is most likely is caused by seized bearings in the turbine, requiring shop service (easy fix). The suction issue can be caused by the standpipe seal missing or lower recovery tank not on properly, on some models missing front panel. I would need more exact model info to assist further.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
SOURCE: Hoover SteamVac Dual V Carpet Cleaner # F7410-900
"I did some research online and the recurrent theme was a bad turbine assembly. Fortunately I was able to fix this myself which took about 2 hours (some reading) and little effort. The problem was with the turbine which is fairly simple and had a bearing that had rusted and froze up. Removing the cover proved to be more difficult than fixing the stuck bearing. This was mostly due to figuring out the correct screws to remove and finally discovering that the back of the cover (over the wheels) is not secured by fasteners but by pegs that "pop" out.
Once I had the brush assembly and Cover removed the turbine came out with the removal of some obvious screws and gently pulling the hoses from the assembly. After carefully opening the assembly housing I discovered the bearing problem and with a little lubrication and some new grease had it working in short order. Putting everything back together was simple as well."
this worked for me. although once i got in i just had to mess around with the gears and loosen them up. getting in was the hard part soo here you go peoples.
take off tanks
unscrew 6 screws fom underneath machine. look carefully
just underneath where the dirty tank goes right by the part that sucks everything up is a screw. unscrew it
pop off the switch for your spin scrub mode. it pops right back on.
make sure your locks for the tank are turned in
then the back just pops off. you might have to give it a good tug. there are no screws although it maight look like there is.
then pull off the grey part.
once inside it is pretty easy.
but if you have any questionbs email at [email protected]
i took off so many more screws than i needed to to get this figured out so dont do that.
SOURCE: brushes don't work on my hoover steam vac v2
The bearing on the inside of the turbine is rusted. You will have to take the hood of the unit and unscrew the black piece that has to rub hoses going to it. Then take apart the black turbine. Inside you will find 2 white gears and a small 1/2inch bearing. Use wd40 to uncease the bearing. After this put the take pliers and make sure the metal post will turn. Spray wd40 on everything you see including Hoover for making such ****. After this put put everything back together. Now the best thing to do is get some automotive bearing grease and put a large amount on bearing and and other metal parts. Put everthing back together. Clean any hair off the brushes and you are ready. Now the bad news if your gears are worn you will have to replace the turbine. Go to an internet website and the part number will be 91001019. I know all this because I spent 6 years working for Hoover and they found it cheaper to send our jobs overseas.
SOURCE: Repalcement of belt on Hoover F7425-900 Steam Cleaner
To help out here the hood has 6 screws on the underside of the machine and 2 post snaps at the rear of the hood. They pop out when lifting the rear of the hood. The air motor is as described above, 2 on bottom and 2 on top. When removed the air motor again has 2 screws on the cover of the gear set and a couple clips which come loose readily when the screws are removed. This exposes the gear set. Remove the gears and free the air motor shaft. Clean, lubricate and reassemble. You should be good to go. The Air motor is the only weak link in the machine. The bearings seize due to exposure as moist air is pulled through the air motor to drive the gear set. Great idea! Hoover should have used a stainless drive gear and bearings or a plastic bearing that would hold up to the RPM of the motor. Regardless, as is it will be plagued with the problem for the life of the machine unless you upgrade. Hoover may have solved this for all I know. Hint: The motor will not create any torque until the suction tank is in place. Oh, and keep the screen clean. That is the motor intake.
