I have checked for blockages as per the manual and the water container is correctly fitted. he hard water filter is a ****** colour
I managed to fix mine after a little effort. It was blocked well up in the nozzle into a small pinhole where the steam comes out of the 'small kettle' in the steam mop.
To fix:
You should only really do this if you are competent as there are lots of wires etc. and if your steam mop is not covered under warranty as messing around with it will void this.
Hope this helps :)
The problem is a very frequent one a small scale part have been moved and it stack to the water steam valve and it blocking it from closing completely. So when you make coffee the hose of water for coffee is in parallel with hot water steam wand and since the valve remains partially opened the water for coffee find easy escape from steam wand.
So we suggest to perform one more descale and it may need twice hopefully this small scale part to be dissolve a little bit more in order to pass thought the steam valve and thus the valve can close again completely. If you are not so lucky the part remain on the valve then only solution is to disassemble the machine thus clean the steam valve manually. In this solution you may find out that the valve o ring might be damage and thus the leak.
here is the link with steam valve parts and this the parts diagram of the machine and here many more for your machine
