I have a soniq dual screen portable dvd player,QMD88ds only a month of use and now when you insert a disc it says loading for about 3 min then NO DISC wont recognise any disc
  • 10,515 Answers
There are common errors. However, i am surprised tat you bought the unit a month ago.Make sure that you are using correct DVD. Try to use some other DVD that you might have used previously and worked on it.
Usually, we do advice the people to clean up the DVD as the main reason for this error is 'Dust Accumulation'. However, as the unit is only 1 month old, i don't guess it would be an appropriate to say that there is dust accumulation unless you must have it in junkyard.
More likely, it seems to be a Laser Head.
My bet - RETURN IT AS SOON AS POSSIBLE AND GET A REPLACEMENT AS THEY USUALLY OFFER 1 YEAR WARRANTY.TRY TO AVOID THESE KIND OFF PLAYERS.
Always better to read the reviews before purchasing any player.Do not open the unit or it will void your warranty. If not under warranty :-
Open the unit. Remove the DVD drive. Take the top off of the DVD drive. Clean the lense with a q-tip with a little windex on it. Work the head up and down gently. Reassemble and test. If problem presists, go buy a new one.
This would be the precise solution. I know its frustrating, but i would NOT advise you something that would be against the ethics.
Hope i helped you.
DO RATE THE SOLUTION.
Thanks for using "Fixya".
Posted on Jul 01, 2009
I have a Sylvania 32 inch DVD not reading the DVDs what's wrong???
How To Fix a Portable DVD Player That Is Not Reading or ...
? 17:12
https://www.youtube.com/watch?v=ucNedtR256g
Jan 18, 2015 - Uploaded by orly lando argallon
How To Fix a Portable DVD Player That Is Not Reading or Loading Discs. ... 2:32. How To Clean A DVD ...Missing: inch
Amazon.com: Sylvania SDVD9805/SDVD9805-C 9-Inch ...
www.amazon.com/Sylvania-SDVD9805-SDVD9805...
Amazon.com, Inc.
Rating: 2.9 - ‎916 reviews
Sylvania SDVD9805/SDVD9805-C 9-Inch Twin Dual Screen DVD Player. Sorry .... 5.0 out of 5 stars32+ hour car trip ... One remote does not work on both, only works for the one it came with. .... Garbage, 3 months in the first of the two DVD players stoppedreading the DVD's so we only used the one and now 5 months in the ...
Sylvania SDVD9805/SDVD9805-C 9-Inch Twin Dual Screen ...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Sylvania SDVD9805/SDVD9805-C 9-Inch Twin Dual Screen DVD Player at Amazon.com. Read honest and ...
Jan 20, 2016 | Sylvania Televison & Video
Disc does not appear to load. When inserted in
If you have a disk that you know works, try it. Make sure the disk is not upside down.
Dec 29, 2009 | Polaroid PDV-0823A Portable DVD Player
DVD player not reading disk
Clean the laserunit,if fault still exist then replace the laserunit
Aug 27, 2009 | Televison & Video
DvD Player will not play disc
The discs got warped due to heat.
Sep 05, 2017 | RCA DRC629N Portable DVD Player
Won't play movie...only loading screen
The cause of this is a dirty pickup laser, a DVDcleaning disk might be of help.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
May 24, 2009 | TruTech PVS12701 Portable DVD Player
Coby DVD Player wont play
try running an optical disk cleaner it worked for me but I have to clean often.........a cheap fix if it works.
Jan 26, 2009 | Televison & Video
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
Portable DVD player not spinning says no disc
Check to see if the disc is spinning. You can do this by one of two ways either
  • a:) Listen for the disc to spin after inserting it or
  • b:) Place disk in drive right way up (so that the label is not upside down). Load the disc and eject the disc again to se if the disc has moved i.e. the writing may now be upside down.
If the disc does not spin then it is likely that there is something wrong with the disc motor. If it does spin then the issue is more likely to be with the laser unit. Try cleaning the lens but if this doesn't help it's likely to be a more serious and ultimately more expensive problem.
Hope this helps
Feb 02, 2007 | Centrios EDW8020 DVD Recorder
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
