Microwave Ovens Logo
A
Anonymous Posted on Aug 16, 2014
Why microwave won't stop running unless door is open ?
Why does my over the range microwave keep running unless I open the door?
Ronald Rissel
Level 3:
Master:
  • Whirlpool Master 715 Answers
  • Posted on Jan 25, 2015
Ronald Rissel
Whirlpool Master
Level 3:
Master:
Answers
715
Questions
Helped
259067
Points
1075
Is it actually heating or just making noise and acting like it's heating? (put a cup of water inside and close the door.) IF it's actually heating, then you have a shorted relay on the main control board, and you will have to replace the board. IF it's just making noise like it's working, but it's not heating, then the problem is 1 of the door switches is not working right (it's either stuck open or stuck closed).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
5 Related Answers
Anonymous
  • Posted on May 26, 2007
SOURCE: Over the range microwave
I have the R-1460 in the same series with the identical symptoms. After reading MicrowaveSvc's solution I started taking apart to view the door switches and found the upper door switch to be the problem, but not a switch failure a support failure. A small bottom plastic support post that holds the switch in place was broken (probably from repeated use/abuse) allowing the switch to move when the door hooks were engaged, thus not actuating the button switch. Since the problem was mechanical rather than an electrical bad switch, I made a small support arm for the switch from an old plastic mechanical pencil and glued it in place to hold the switch in its correct position. Problem solved, microwave works! Thanks to MicrowaveSvc's description of door switches.
Anonymous
  • 52 Answers
  • Posted on Feb 21, 2009
SOURCE: Microwave keeps running after door has been opened
this is potentially a major design fault and could be dangerous. contact the manufacturer immediately.there are other post on the site saying the same
Anonymous
  • 52 Answers
  • Posted on Feb 23, 2009
SOURCE: Our Microwave keeps running unless we give it a whack!
Hi firstly to see if it is producing energy, buy some 5mm light emitting diodes from an electronics store. cut off the leads close to the plastic body.
place in microwave and put on cook for max 10 secs, if the led's light up you have microwave energy, shut off the oven as soon as they glow otherwise you end up with a mess.
If you have energy then your problem is most probably the door interlock micro switches which after time do not operate properly. let me know the results and we can go further.
Anonymous
  • 4088 Answers
  • Posted on Jul 16, 2009
SOURCE: ge profile microwave oven runs when door is open
Good way to cook yourself! It has to be a stuck door interlock switch--the case needs to be removed to get at the switch. It could be either the mechanism that operates the switch or the switch itself is bad. The switch normally makes a click when the button is pressed. Unplug the unit when the case is removed.
Anonymous
  • 1891 Answers
  • Posted on Jan 04, 2010
SOURCE: Microwave runs constantly
you have a door inter lock sw/ failure . replace the sw. there 3 .. ir they click there probably good . one of them does not click . primary sw secendary sw . and mont sw . .. a very common problem with all brands of micro's //
2answers
IT KEEPS RUNNING UNLESS YOU OPEN THE DOOR
1. Defective door interlock
2. Control board failure
My turntable keeps running when i open the door is this a serious problem and can i still use it
Does it not stop at all...?
If not I would say to dump it unless it's expensive microwave- if so get it repaired.
It may be emitting microwaves and cooking you, a bit, each time you're opening it.
Why is the microwave running without being turned on?
These above range microwaves "hoods" automatically turn on a cooling fan even when the microwave is not in use. If you read the manuals you will see warnings about the fans automatically starting. Even when the microwave is not in use opening the door likely interrupts the power to the automatic cooling fan.
Microwave won't stop running
my microwave door wont shut
GE OVER THE RANGE MICROWAVE DOES NOT STOP WORKING
You probably have a shorted cook relay.
We regularly repair this problem with our $39.95 service, or you can order a new circuit board from the Pros here, our favorite supplier.
4helpful
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
1helpful
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
1helpful
Have plugged in new from box microwave is running when door closed and won't stop unless door open
There is a problem with the door switches or a ground short. I would suggest to return it or have the dealer look at the problem, not a big deal to repair, but does need to be corrected.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Top Whirlpool Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
