Question about Canon IXUS i7 Digital Camera
Card locked at all times
When ever I turn the camera on it says card locked. It does not make a difference what position the lock feature on the SD card is in. Any suggestions?
  • sparky101 Nov 09, 2007
    I have tried a different SD card and it does not change the problem.
  • Anonymous Dec 13, 2007
    i have the same problems, but when i use the card on other camera it works perfectly and i can even see the pictures at the Ixus i7 but it keep saying "card locked". i've contacted a Canon dealer and they said that i should send the camera to repairing because it might be a physical problem inside the camera.
    cheers
    Scholar:
  • 97 Answers
Have you tried another card? It's conceiveable that the lock on the card isn't working properly. Alternatively the contacts on the camera that connect to the card could be damaged, perhaps.
Posted on Nov 09, 2007
Insert sd card again
At this time we recommend you use a different SD card and format it. SD cards can become corrupted and the camera may not recognize your card any longer.
Apr 13, 2014 | Panasonic Sale Lumix Dmc-ts20 Waterproof...
Tip
My Digital Camera Will Not Save My Pictures - The First Thing to Do
If your camera will not save the photos you take, the first thing to do is to make sure that the SD card, your camera's memory, is not locked. Open the memory access door on your camera and remove the SD card. On some cameras, the SD card is in the same compartment as the batteries. Check to see that the write protect tab on the SD card is in the unlocked position. Hold the card so that the label is facing you with the angled corner to the top right. Look along the left edge and find the very small slider switch. Slide the switch up (down is locked and up is unlocked) and replace the card in the camera. The locked position is provided as a safety feature so that you can prevent an SD card with important pictures from unintentionally being erased.
on Jan 31, 2015 | Cameras
Tip
How to Unlock SD Card
<p>Many times people do not realize that a <span style="font-weight: bold;">SD card</span> can be <span style="font-weight: bold;">write protected </span>or locked. They will <span style="font-weight: bold;">try to download pictures</span> or <span style="font-weight: bold;">make changes to the pictures </span>and the <span style="font-weight: bold;">SD card will not allow</span> them to do it. The little lock feature on the side of the card will <span style="font-weight: bold;">write protect the SD card</span> so that changes cannot be made. You will need to <span style="font-weight: bold;">unlock the SD card</span> to be able to make the changes that you want to make or download anything from it.<br /> <p><br /> <br /> <p><span style="font-weight: bold;">To allow the SD card to be accessed</span> is a simple as sliding a small tab on the side of the card to the <span style="font-weight: bold;">unlocked position</span>. Usually this means sliding the tab towards the back of the card and away from the front of the card. The card will have to be removed from the <span style="font-weight: bold;">camera</span> or <span style="font-weight: bold;">PC</span> to be able to do this.<br /> <p><br /> <br /> <p>Here is a <span style="font-weight: bold;">picture of an SD Card</span> and you can see the tab on the side of the card. It clearly shows you what is the locked and unlocked positions on the card.<br /> <p><br /> <br /> <p><img src="heatman101_2.jpg" /><br /> <br /> <p><br /> <br /> <p>This feature can be very useful to make sure that you do not inadvertently <span style="font-weight: bold;">erase data or pictures</span> from the card. If you have children viewing pictures on the SD Card make sure to lock it before allowing them to play around to make sure that they <span style="font-weight: bold;">do not erase your pictures</span>.<br /> <p><br /> <br /> <p>As you can see this is a very good feature to have and it will be very useful to you, but you do need to remember to unlock it before trying to make changes to the card.<br />
on Apr 21, 2011 | Cameras
WHEN I TURN CAMERA ON IT READS CARD LOCKED
You didn't specify the make and model of your camera, so I'm going to assume it uses SD cards.
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't do it, try a different card.
Feb 18, 2011 | Cameras
Sd kart problem var ekran da ( the card is locked.unlock the card to access delete features.) yazmaktadir hizli bi sekilde cozumler seniz sevinirim
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jan 12, 2011 | HP Photosmart M447 Digital Camera
My camera says my memory card is locked but the button on the side is not locked how do i retrieve my pictures i have a canon powershot a480
Issue: [Memory card locked] message appears on the screen.
Solution: Change the memory card lock switch to the normal setting
The SD card has a lock switch to prevent existing data from being erased. To record images or movies this switch must be in the normal (non lock) position. Different brands of SD memory cards may identify this switch differently. Regardless the procedure should be the same. Please remove the card from the camera and ensure that the switch is not in the locked position. sdcardlocked.jpg
sdcardunlocked.jpg ---
You should be able to retrieve photos, but not writing or erasing if the switch is switched to write protect.
If it's not functioning correctly, the camera may need service at Canonusa.com.
Jun 19, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Camera says card is locked but it's not!!!
You already know about the 'lock' switch on SD cards; did you know it doesnt actually lock the SD card by itself? It merely pushes a switch lever in the reader (in this case, your camera), that in turn tells the electronics to NOT write on the SD card.
So, if your SD cards are indeed working (check on a card reader), it would look like the lever in the camera that senses the position of the lock switch is jammed / bent. If you could pry into the card slot in the camera, and try to shake this lever with a long narrow object (a straightened paper clip, perhaps), that might yield good results.
Alternately, look up 'CHDK' on Google; it is an alternate OS that gives your Canon *lots* of other features. In your case, more importantly, it *requires* the SD card to be locked in use. Dont worry, with CHDK booted in, the camera will store pictures even when it sesnses the card is write-protected. So, it not only solves your problem, it gives you loads of extra features like RAW capability, time laps, remote operation and more, all for free.
Regards,
Anand Dhuru
Apr 21, 2010 | Canon PowerShot A710 IS Digital Camera
Have a new Canon Camera with 2gb SD card. Card was OK at first but now comes up as card locked. Installed in a different camera with same results. Lock switch on card is in unlock pos.
Hello. your SD card has a tiny switch on the card itself which locks the card in one position and unlocks it in the other. The purpose of the lock is to prevent anyone from formating it and losing it's contents. Check your card and I believe you will find that the card slid into the lock position because it was never firmly put in unlock.
Regards, Joe
Dec 26, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Memory Card Error
The SD card has a lock switch to prevent existing data from being erased. To record images or movies this switch must be in the normal (non lock) position. Different brands of SD memory cards may identify this switch differently. Regardless the procedure should be the same. Try removing the card from the camera and be sure that the switch is not in the locked position.
Jan 01, 2008 | Canon PowerShot A450 Digital Camera
Locked Card
Take the memory card out of the camera. Look at it carefully and you will seea small tab. Move the tab from the locked position to the unlocked position. Re-install the memory card into the camera and then you're done.
EEee
Nov 03, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon IXUS i7 Digital Camera Logo
96 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
