Question about Car Audio & Video
My cars splutering like a suby wen u try accellerate
  • 35 Answers
Did u ever changed ur muffler, converter or any thing with the exhaust...sounds like ur intaking air some place, or it cud be ht u need a tune-up..
Posted on Jul 16, 2009
Car has started give spluters when taking off from low revs but of at higher reves
Have catalytic converter checked. Additionally have a pressure check run on you fuel pump. Pump maybe getting ready to fail. Additionally change your fuel filter
Sep 17, 2015 | Cars & Trucks
Reset timeing on 1990 subaru legacy
Hi Jeff, The timing is set and controlled by the computer, but you can manually rotate the distributor. When I had pulled the distributor out of one of my suby's, it got bumped and rotated. I simply inserted it and hooked up the plug, tried to start the car and if it didn't start, re pulled the distributor, rotated the gear by one notch over and over again, until I got it right. If you recently changed the belt and something got moved, I always suggest a Chilton or Haynes manual, either and both have gotten me where I needed to be with my suby's. Good luck Jeff!
Jan 19, 2014 | Subaru Cars & Trucks
1999 passat 1.8s 20v spluters on cold start
you have a problem with the cold start operating device ,but where it is and how this system works on your vehicle i have no idea ,because if your in america they had different emmisions laws when this vehicle was built .
Mar 28, 2010 | 1999 Volkswagen Passat
At 30 it spluters and juders
I know you did the carb. but either you have poor fuel supply (screen in the tank plugged) or your carb is still plugged, usually blowing them out is not good enough unless it is soaked in a carb dip tank then blown out. Most jets and passages still have a build **** in if you don"t have the chemicals to break them down it is neccesary to use something to run through them... I use a torch tip cleaner because of the variety in sizes... It's amazing what comes out of them when you finally get it clean and how big the jets really are...
Sep 14, 2009 | 2001 kawasaki KMX 125
Suby gt legacy
your alternator has died i would replace it and have your battery checked or replaced .....when your alternator quit working it drained your battery right down until it was dead it might not hold a charge any more....i would replace them boath
Apr 29, 2009 | 1993 Subaru Legacy
The motor runs but wont powerband? (yz250)
clean out the entire airbox along with really clean out the air filter, use gas to clean the filter then rinse it out with warm water.iv been doing it for years, dont let anyone tell u otherwise, check the reeds, replace if needed, clean the powervalve. clean the carb. i dont no wat else could be a matter with the bike, unless its in the cylinder like no compression of broken or worn piston rings, who noes. get curious check **** out that away u dont have to waste ur time askin us. u no
Jan 25, 2009 | 2003 Yamaha YZ 250
Check engine light for misfire cylinder 2 and 4
If the engine seems like it's OK but you are just seeing a solid Check Engine Light, and if the light has ever mysteriously gone out on its own, check the Knock Sensor. Over time they rust. I have had the repair done on my 2 subies (a 97 and a 99).
The CEL will go out on its own if you have 4 starts with no misfires. If the knock sensor is out, rapid accelleration or steep hill climbing will make the light come back on as the timing advances and the sensor does not ****** the timing for you, so the knocking becomes a misfire.
May 22, 2008 | 1997 Subaru Legacy
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
