Question about Apple iMac All-in-one - 3.06GHz Intel Core 2 Duo, 8GB DDR2, 1.5TB SATA HD, NVIDIA GeForce 8800 GS w/... Mac Desktop
When i stert my g4 imac,s screen was became blue
When i start my g4 imac,s screen was became blue.I cant see any thing accebt the blue screen
  • Jason Johnson May 11, 2010
    Restart, may be a pram battery issue. Try starting from CD.
  • Luke Kim
    Luke Kim May 11, 2010
    can u specify which imac you have? is yours the one with the screen and all the parts inside the screen, or do you have the imac where you have a screen and all is in the bubble on base.
    either way, i suspect that your monitor has burned out, like a laptops would do. you will need to have it serviced if you still have your applecare. if not then you can find a local apple certified store and order a new screen or goto :
    HeadGaps's used and new store. they are quite cheap.
    Scholar:
  • 50 Answers
You need to reset your pram
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Posted on Jul 29, 2009
Imac g4 freeze restart
This is a sign of memory issues with your Mac. Replacing the memory should not be very expensive.
Oct 10, 2012 | Apple iMac G4 Desktop
Why does the screen of my iMac G4 stay black on start up?
Test the system on an external monitor. If OK, replace the screen.
Jun 09, 2012 | Apple iMac G4 20" Mac Desktop
Imac g4 won't start but shuts down when apple logo appears on screen
Are you sure the iMac is really shutting down or just turning off the backlight? The tell-tale sing would be to let the unit fully boot-up (wait 3 minutes) and the press the button the apple keyboard that ejects the CD-ROM. If the CD-ROM door opens, you iMac is running with disabled or broken backlight.
The inverter circuit on the iMac G4 is known to be weak.
There could be another problem, though. The iMac G4 is also known to have weak internal power supplies. Here's how you can tell:
Hold down the CMD OPT "O" and "F" keys at the same time while pressing the power button. This will tell the iMac that you want to boot into the Open Firmware shell, bypassing the Mac OS X startup. If this works, your power supply is good, the inverter is good and you have a problem with your Open Firmware boot string. To fix the boot string, Power on the unit while holding down the keys CMD-OPT-P-R to zap the parameter RAM (PRAM) and reset everything to defaults.
If you were not able to boot into the Open Firmware shell, your problem is either a failed power supply or a failed screen backlight. The last possible culprit is your iMac could suffer from "Bulging Capacitor Syndrome", where a batch of iMac G4s, iMac G5s another electronics were fitted with a bad batch of capacitors. Eventually, the caps will rupture and cause irreparable damage to the logic board. Only way to verify this is to pull the unit apart and visually inspect. If you see little green or blue cylinders that seem to be bulging or oozing a thick oily goo, that's your problem. Only recourse is to shop around on eBay and look for a replacement logic board.
May 30, 2010 | Apple iMac G4 Desktop
IMac G4 Mac Desktop: imac g4 wont boot up scree's just blue?...
If it only boots to a blue screen, try booting up in Safe Boot mode:
http://support.apple.com/kb/ht1455
If this does not work, boot from your install DVD and use Disk Utility to repair the disk:
http://support.apple.com/kb/ht2956
If this does not resolve the issue you may need to use your isntall disc to perform an Archive and Install:
http://support.apple.com/kb/ht1710
May 18, 2010 | Apple iMac G4 Desktop
Imac g4 lcd black screen replaced pram battery
If you can find an older SVGA monitor, try hooking it up to the port on the back of your mac. If you get video then chances are the LCD display is shot.
Sep 01, 2009 | Apple iMac G4 Desktop
try these articles:
http://support.apple.com/kb/TS1411 also boot to cd and run disk first aid. If it can repair the you have 3 options 1: try 3rd part utility program such as disk warrior or drive genius. 2: try to back up.. you can use target disk mode and hopefully you hard drive will mount, if you dont know how to do target disk mode do a search. if not drive saver can save data but it's expensive 3: erase and install
Jul 01, 2009 | Apple Computers & Internet
Imac g4 dead
Hello, The power supply is part of the motherboard in the iMac G4, so it's hard to change it. The repair would certainly cost more than the price of your iMac. You can try to take off the small battery, and reboot it to see if it changes. To open the mac lay it down, screen on the table (on a t-shirt). Unscrew the four screws (they wont come out, so just unscrew them. Pull the screws and take off the silver plate. Then you'll have access to the inside. Good luck
Jun 12, 2009 | Apple iMac G4 Desktop
I book g4
Some of the start up files have been corrupted or are missing. Start up from the OSX system disc and them run Disc Utilities from the installer toolbar. Check the hard drive for errors. Repair any errors if they are found. If it's not possible for Disc First Aid to repair the hard drive you will need to replace the drive and re-install OSX.
Dec 30, 2008 | Apple iMac G4 Desktop
Apple iMac All-in-one - 3.06GHz Intel Core 2 Duo, 8GB DDR2, 1.5TB SATA HD, NVIDIA GeForce 8800 GS w/...  Mac Desktop Logo
253 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
