Question about Acer Cameras
How do i copy images from the internal memory to the memory card
I want to transfer images from the internal memory to a memory card in order that I can print the image
    Habit-Forming:
    New Friend:
  • 22 Answers
CONNECT YOUR CAMERA WITH COMPUTER THROUGH A HDMI CABLE
Posted on Aug 16, 2014
SOURCE:
neta
  • 852 Answers
SOURCE: Move images to the internal memory to the optional xD-Picture Card?
The images saved to the internal memory can be copied to the memory card, but you cannot copy images from the memory card to the internal memory.
Posted on Aug 31, 2005
SOURCE: Transferring images on camera memery onto memory card.
I had the same problem, and I found after much playing and mostly accidental findings that I could do this by following these steps
1. Put an SD card in the camera. Will not work otherwise
2. Go into playback mode, where you view the pictures, button looks like an blue arrow pointing to the right
3. Press the round 4 way controller downwards, and a menu (that I have never seen before!) appears
4. Choose the 4th icon along on the top line and that will give you options to transfer from memory card to camera and the other way around.
Posted on May 13, 2008
welcomejee
  • 10594 Answers
SOURCE: transfer images to memory stick from internal memory
Please insert memory stick in camera, power it up and press Menu >> Copy >> OK
That will copy internal memory pictures to memory stick.
Posted on Apr 26, 2009
welcomejee
  • 10594 Answers
SOURCE: how to transfer internal images to sd card?
Put memory card in camera, power up, go to menu and find copy option, select it and press ok.
That will copy picture files from internal memory to memory card.
Posted on Jun 17, 2009
RadarRon
  • 398 Answers
SOURCE: How do I transfer images
You can only do that with use of a cable and a computer. After you transfer from the camera to the computer then you can transfer to a memory card.
Posted on Dec 03, 2010
How to transfer internal memory to memory. When I inserted the card, the images became 0.
I'm sorry for the difficulties you're experiencing in copying images from Internal Memory to the Memory Card. Unfortunately, COPY option is not available in DSCT700.
You may connect the Camera to Computer after removing the Memory Card to transfer images from Internal Memory to Computer. And then insert the Memory Stick and transfer back to Camera to copy the images to Memory Stick.
Only few Cameras do not have the COPY option. Unfortunately, you're one of the victim.
You can confirm the information from the Handbook of the Camera.
Click hear to download the Handbook for the Camera.
Thanks for understanding. Please let me know if you require any clarifications.
Aug 06, 2011 | Sony Cyber-shot DSC-T700 Digital Camera
Tip
If your camera will not read or transfer internal images on to memory card
When your camera will not transfer images onto memory card this is often because the image storage has been set to 'Auto'. You need to set it back to internal memory temporarily to allow you to copy the images over to the card. Once you have done this you can set the camera back to 'Auto' and this will reset the system and you will now have access to all of the images on the card.
This particular procedure works with all cameras but the steps outlined here are for Kodak in particular.
Please follow these steps;
1) Insert the card
2) Turn the camera to Auto
3) Press review - "reading memory card"
4) Press menu and scroll down to image storage and press ok
5) Select Internal Memory and press OK
6) Scroll down to Copy - Copy Pictures to memory card
7) Scroll down to ALL and press OK - you should see "Copying" displayed
8) When the screen goes back to the main menu - Scroll to Image storage again and select Auto - OK - "Reading memory card"
You should now be able to see the pictures from your internal memory saved onto your memory card and your camera is once again ready to use.
Hope this helps. Please do register your vote using the Yes/No buttons below to reflect the helpfulness of this Tip.
on Dec 22, 2009 | Cameras
I took pictures on my camera without a memory card can i still download my pictures
I'm glad to provide the steps to transfer images from Internal Memory of the Camera. When the camera does not have a memory card in it, the images are saved by default to the camera's internal memory, which holds different amounts of images based on how many megapixels are built into the internal memory and what image quality and compression are selected in the camera's menu. Once a memory\picture card is inserted in the camera, the camera then saves the photos to the memory\picture card and ignores the internal memory.
There are two ways to transfer the images from the internal memory.
  • To transfer photos to a computer from the internal memory using the USB cable, first remove the memory card from the camera. Then, when the camera is connected, the computer and software will only see what is in the internal memory and transfer those photos or videos. During the transfer process, the computer makes copies of the photos and videos-the original images remain in the internal memory. After the transfer is complete and the camera is safely disconnected from the computer, the contents of the internal memory can be deleted by using the MEMORY FORMAT function in the SETUP menu in the camera's menus.
  • The other way to transfer photos from the internal memory is to transfer them to the memory\picture card using the BACKUP function in the SETUP menu. If there is no memory\picture card in the camera, the BACKUP function is grayed-out. During BACKUP, copies of the images are transferred to the memory\picture card-the original images remain in the internal memory. After the BACKUP is complete, the internal memory can be cleared by removing the memory\picture card and formatting the internal memory using the MEMORY FORMAT function in the SETUP menu in the camera's menus.
Note: When the camera is connected to a computer using the USB cable with a memory\picture card in the memory\picture card slot, the computer will only see the contents of the memory\picture card.
Thanks for understanding. Please let me know if you require any additional help.
Jun 16, 2011 | Olympus Cameras
Camera is saying internal memory card is full. I have a memory card in there. How do I switch to the memory card?
Welcome to FixYa.
In order for you to transfer pictures into your memory card , just follow this steps.
  1. On the camera, press Review and then Menu.
  2. Select Image Storage.
  3. Change to Internal Memory.
  4. In the menu listing, scroll down to Copy, and select OK.
  5. Select a single picture, or select All.
  6. When you have finished copying pictures, reset the Image Storage location to your original setting.
NOTE: You can also use a card reader to transfer picture files to a memory card.
If you need for information about your camera, here is the link for your free manual. Just click here.
Fell free to send us comments or suggestion if this information was helpful or not.
Thank you for using FixYa.
Apr 06, 2011 | Kodak EasyShare C180 Digital Camera
Internal memory is full on our M580 Can not toke pictures
I copied this from Kodak website Good Luck!
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card?
Follow these steps:
NOTE: You can also use a card reader to transfer picture files to a memory card. For more information on card readers and memory cards, go to KODAK Memory Cards
Sep 05, 2010 | Kodak Easyshare M580 Digital Camera
I have images on the internal memory that I would
Select Copy from the Setup menu to copy pictures to/from internal memory.
Feb 12, 2010 | Nikon Coolpix S210 Digital Camera
Transferring pictures
Go into the Setup menu and select Copy. This will copy all images in internal memory to the memory stick.
Jan 27, 2010 | Sony Cyber-shot DSC-W100 Digital Camera
Pix transfer from internal to card
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
Jan 10, 2010 | Kodak EasyShare DX6490 Digital Camera
Kodak easy share wont delete or scan to the left to view pics
In order to solve the problem you need to transfer pictures from the internal memory to the SD card and thereafter you will be able to delete the pics in the internal memory.
Follow these steps:
Dec 22, 2009 | Kodak EasyShare CX7300 Digital Camera
How to transfer internal images to sd card?
Jun 17, 2009 | Fuji FinePix Z10fd Digital Camera
Cameras Logo
24 people viewed this question
Top Acer Cameras Experts
Bill DeLisi
Bill DeLisi
Sumeet Sodhi
Joseph Hoffmann
Are you an Acer Camera Expert? Answer questions, earn points and help others
