Question about Hampton Bay 24750 Huntington III Ceiling Fan
Light works fan doesn't light has power no power going to fan switch suspect speed control
  • 615 Answers
1. may be problem with switch
2.try by replacing fan condencer it usually fails after a certain months or years.
Posted on Jul 01, 2009
Wall switch control not working
Fan speed and light intensity are controlled by the remote as indicated in the instructions for the fan.
Dec 12, 2013 | Hunter 1912 Mission 21978 Ceiling Fan
Fan only runs on slow speed
The receiver in the fan housing may have failed.
Apr 20, 2017 | Hunter Dryers
04 Saturn vue compressor turns off when fan is set to 3 or 4
The problem is the blower motor speed control resistor, it is located near the blower motor in the housing. I exchanged mine and it works like a charm now.
May 31, 2012 | 2002 Saturn VUE
Po 480b cooling fan relay 1 control circuit what exactly does that mean?
Lets take a look at the relay first. This is a device that takes a small amount of voltage (computer signal), and passes it off (through a magnetically induced switch) to a higher voltage- like a relay race.
The circuit would consist of a power source (battery), wiring, a switching device (sensor and computer), relay, fan, and ground. According to the trouble code, the indication is that something along this circuit is defective or malfunctioning.
For a do-it-yourself diagnosis, first you wanna check the fan to see if it can free spin. This will confirm that it isn't siezed. Next you wanna start the vehicle, and let the temp gauge go to halfway. The fan should activate. If it doesn't, turn on the a/c. If this cuts the fan on, then the relay is working. If it doesn't suspect a faulty fan relay. In the event that the a/c does cut the fan on, then suspect a faulty coolant temp/fan switch.
Sep 20, 2011 | 2003 Chevrolet Impala
The 15 min timer doesn`t work anymore tried getting a new switch and still nothing. Any suggestion?
Fan or electrical wiring or power source are suspect.
Fantek RTS2 is supposed to boost HRV/ERV system into high speed for 15 minutes.
http://www.iaqsource.com/category.php/fantech-ervs-and-hrvs/?category=1494
If new RTS2 is not working, then either the wire to HRV/ERV system is suspect, unit is not getting power, or the HRV/ERV system is suspect.
If you are using RTS2 for ordinary ceiling fan, then install regular on-off switch and see it that works.
Check that you are getting power to switch and to fan. Check circuit breaker.
Jun 22, 2011 | Fantech RTS2 15-minute Pushbutton Timer w/...
I have a 1997 oldsmobile eighty-eight and the fan one day over the summer 2010 went off and on with the blower switched on. It caught my attention but kept my fingers crossed. Within a few days the fan...
It does sound like a bad switch --- possibly arcing and overheating -- or it could be dirty / corroded contacts on the switch or in the wiring harness connector.
The switch should come out fairly easily after getting access to the back of it -- it probably has tabs on it which when pressed in will allow the switch to come out the front.
Charlie
P.S. The blower motor resistor would not cause an overheating switch -- a bad resistor would at worst allow maximum current to go through the switch -- the switch is designed to run the blower at full speed (maximum current) w/o overheating...
Jan 29, 2011 | Oldsmobile 88 Cars & Trucks
The switch does not control the speed of the fan.
I WOULD THINK THAT THE POWER SUPPLY FOR THE FAN IS WIRED BACKWARDS ANDTHAT WOULD EXPLAIN YOUR PROBLEM SWITCH THE FAN WIRES ONLY! ! ITHINK YOUR HOT IS GOING INTO THE FANS NUETRAL
Jun 24, 2009 | Leviton 878RTD0110W Do it Best Fan and...
Remote control stopped working
Under the dome (where the electrical connections are) is the receiver unit for the fan. It could be that it is no longer working. Also the remote may have dip switches to change the frequency channel (sometimes located behind the batteries) check that these have not been changed or check they correspond to the receiver unit on the fan.
Jul 22, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay 24750 Huntington III Ceiling Fan Logo
269 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
