Question about Maytag Refrigerators
Ice maker froze so we lowered temp and it started making ice again. now there is alot of water coming from underneath the fridge...help
  • 232 Answers
Remove the water valve leave supply line hooked up put it in a bucket turn on water, if bucket stays dry over night valve is good put it back in.remove icemaker check for for cracked fill tube or cup. no cracks put back in check tube alighnment check for level. is it over filling adjust fill time to minimum and try again also a model # helps
Posted on Jul 01, 2009
New (3 days old) Kenmore Elite refrigerator model 795.7103 with ice maker. Water supply line to the ice maker immediately froze up so won't fill tray to make ice. Serviceman came out and melted ice...
First of all, your freezer should be much lower than 38 degrees. For the ice maker to even work proplerly it has to be below 10 F. Some models have a heater that goes around the fill tube to keep that from happening, but in my opinion, if its only three days old, take it back because it's much too soon for that problem to be occuring.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Nov 10, 2010 | Refrigerators
Water not going to ice maker
That happened to me once and while it was with an older fridge, it's possible it could be the same problem. In my case, the water inside the supply line actually froze. Tried using hot towels and such on the water supply line but in the end, I had to empty out the Fridge and defrost it for a day. Water for the ice maker worked again after that... and I had a clean fridge!
Hope this helps...
Mike
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Turned Whirpoll ED22PE off and moved to install new flooring. Put back to previous location, connected water and elect...would not make ice. Someone said it has a temp sensor and must be 10 deg b4 making...
If the water valve is leaking a bit, it will cause freezeup, as will a flow restriction. The 'water splashed inside freezer' sounds like leaky shut-off valve.
Sometimes those 'saddle pirecing' water shutoff valves get restricted, so you are not getting enough pressure.
Also, if you had things disconnected, a little bit of grit may be in the filter or shut-off valve, causing issues.
I would:
a) check the house water pressure, to make sure it's normal
b) check/clean/replace fridge water filter
c) inspect/replace saddle valve and look for kinked water feed line
d) backflush water out of fridge, if possible, and look at clean/inspect/replace water valve.
Although they do make add-on heater kits for water maker feed lines, your issue just sounds like a water flow issue...either a leaky valve or a flow restriction.
Nov 02, 2009 | Whirlpool GS6NBEXR Side by Side...
The icemaker calls for water but no water comes into it
Starting from the start, make sure the valve behind the fridge is open. then make sure when you disconnect the tube from the intake of the refrigerator, that water comes out. Then check the intake filter on the fridge for debris. Then defrost the freezer in case the intake line froze. If you still have no water going into the ice maker, the valve is probably bad. If you post the make/model and go through those steps I'll help you take the Icemaker apart...
Oct 11, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker will not produce Ice
Make suer the freezer temp is 5 degrees or lower. If not the ice maker will not operate. Also make sure that you have water pressure at the back of the fridge. If so, you most likely have a bad water valve. It is what your water supply connects to. You can test it like this. Disconect the water line on the fridge side of the valve. Unplug the wires from the valve. Supply 110v to the plug. If water comes out from where you disconected the line, the valv is good. If not, you will need to replace it. If you can't find the answer with this. Reply back and I'll talk you through until we find it.
Please rate this solution if helpful.
Aug 21, 2009 | Kenmore Refrigerators
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
KENMORE ICE MAKER STOPPED WORKING
MAKE SURE THE ICEMAKER IS ON,ON OFF BUTTON OR LEVER IN DOWN POSITION,CHECK TUBE BEHIND ICE MAKER PULL IT OUT LOOK IN IT LOOK IN FREEZER HOLE TO MAKE SURE IT'S NOT FROZE UP,CHECK WATER INLET VALVE ON LOWER BACK OF FRIG.,LOOSEN CONNECTION TO SEE IF GETTING WATER,IF WATER IS COMING OUT IT IS A BAD WATER VALVE ONLY ONE SIDE TO WATER DISPENSER IS WORKING,VALVE IS NOT OPENIBG TO ICEMAKER SIDE,THANKS-MIKE
May 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker
Disconnect the plastic hose at the top of the refer (the one coming from the water valve) and set the end into a glass. After about two hours you should have water in the glass. If you have water in the glass then the spout that is inside the freezer is froze up and needs to be thawed out (use a blowdryer), If there is no water then it will be the valve or ice maker.
If it is froze up, adjust the cold controls back to the middle settings, you may have it to cold in your freezer.
Jan 18, 2008 | Frigidaire FRT17G4B Top Freezer...
Our fridge does not make ice - Whirlpool Gold side-by-side GS5SHAXNT00
Can you lower the ice maker temp on that model.
Thanks J
Jan 05, 2008 | Freezers
Refrigerators Logo
93 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
