Pure Jongo T6 Wireless Speaker Logo
A
Anonymous Posted on Aug 16, 2014
Bluetooth pairing problems
I am having trouble pairing my sony mp3 mwza828 to the jongo. Sony cannot find the device. Any idea why? I have no problem pairing with other Bluetooth devices.
2answers
Bluetooth in Mercedes CLK 500 Dropping
Do you need to have an app that it has to be connected to?
1helpful
Pairing code of Sonay Vaio VGP-BMS21?
Try this
> (Go To) Control Panel > Bluetooth Devices
If your device is already there
Highlight device then in menu bar select Remove Wireless devise
Click on Yes
When device removed or if it was not there in the first place
> Add Wireless Device
When computer finds your device select it
Click on Next
Choose Pair without CODE
Click on Next.
Computer should then install drivers
This works with my Sony VGP-BMS33
2helpful
My iphone asks for a four digit code to pair as a bluetooth device with my sony xplod, how do i enter the 4 digit code into my sony xplod?
You enter a code on the source device, enter the code again on the head unit (using the remote control is the easiest way to do so), and the two devices connect.
Hello...i am using sony ericsson k550 i had a trouble in that i cant send any files through bluetooth my bluetooth is not working pls any one tell how to solve this prob
Make sure your phone and the other Bluetooth device are charged, switched on and within range of each other. Make sure Bluetooth wireless technology is turned on, and that the devices are set to be visible for other Bluetooth devices. Check that the two devices are paired, and have found each other. If there are still problems, you'll have to reset the connection and pair the two devices again.
In some Bluetooth installations, you must activate a COM port manually in your computer. This is done differently for different brands and models of Bluetooth devices. Please see the manufacturer's product documentation.
If a COM port is not activated
1. In many cases, you can right-click on your phone icon in the window where all found Bluetooth devices are shown, and select a 'COM port activation' item in the menu. Make a note of the COM port number of the activated port.
2. Open Sony Ericsson PC Suite and click Tools/Phone Monitor Options.../Com Ports. Enable the COM port you activated in step 1.
3. Keep the Bluetooth wireless technology turned on in your phone, restart the computer and try to connect again.
4helpful
2answers
Ps3 at v3.15, sony headset paired but cannot get speaker on tv
Go to the Audio Settings above the Bluetooth setting and change the Audio output to "wireless headset"...
Blackberry won't pair with sony bluetooth
Can you try these steps even if you have already failed - so it is clear exactly where your problem lies and how your blackberry is behaving.
Turn on your Sony device and activate the bluetooth feature, set it to pair or search for a device (if this is a headset, it will search automatically, once it is turned on)
On your Blackberry choose the bluetooth option and enable
At your next prompt, when asked ensure your bluetooth device is in pair mode - Say Yes
It will go through a searching for devices screen
Here you will find a list of bluetooth devices in your range that can be paired - (these devices should include your sony)
If at this point you get a message stating no new devices found - Say Ok
Do you see a list of previously paired devices which includes your Sony?!
Let me know how you get on with the above, and what if any error message you receive.
2helpful
2answers
Bluetooth file sharing problem
You can transfer only media files (don't know why). To do it, go to media, prees "menu", select "recieve using bluetooth" and after that send from sony ericsson.
1helpful
Bluetooth headset wont pair to pc
i fixed this problem by enter "0000" (four Zeros) as the passkey, it accepted it and it didnt ask me to enter the passkey on the remote device ie the headset ,which is handy as it doesnt have any number keys ;)
it then added the device and it stayed on teh "added devices" list!
hope this helps
5helpful
2answers
Sony Ericsson W900i Pairing With HBH-608
turn the bluetooth on wait 10 seconds after the bluetooth has turned on. after it has turned on hold the (+) & (-) volume buttons at the same time for about 5 seconds. the light on the outside will then start to flash green and red, and it is ready to pair to your phone.
Pairing Problem
It may be that the phone does not play music through bluetooth and that it only plays through the earphones that come with the phone. The only way to find out is to read the documentation on the phone or try another bluetooth headset, really. The headset cannot be faulty as it pairs correctly and it works with calls. Bluetooth headsets are not really intended for playing music as it drastically reduces battery life.
Top Pure Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Pure Audio Player and Recorder Expert? Answer questions, earn points and help others
